Design Profile ISO 68-1 M Thread Sketches (SolidWorks or Any CAD)
Hello,
I’m curious what others are doing for accurate design profiles for threads, internal and external. I know some use a thread tool, I’m not asking about this, I’m aware of it (in SolidWorks) and know how to modify the profiles and use it. I’m looking for machinable or accurate design profile threads.
Assuming a swept profile around a helix, how are you dimensioning the thread sketch profile using the data form a calculator or Machinery’s Handbook? I get the form is simple, it’s a truncated triangle or a triangle with a radius, but it really depends on the tool making the threads, right? Assume machined thread with root radius for the moment. There are several ways to ‘define’ the sketch using the values provided in the book or from the calculators.
  • dimensioning the pitch diameter + root radius
  • dimensioning to the root radius + tangent of the root radius to be the Minor diameter?
  • dimensioning to height of the profile or width of root, truncation of triangle…etc. etc.
It seems the ‘proper’ way to measure the threads is based on the pitch diameter over wires. But the machinist only knows the tip of his tool position and it’s radius. So is the ‘proper’ way to dimension the sketch to the tangent of the root radius with the root radius specified?
If anyone has a sketch or nut + bolt thread assembly (SW) they could share containing proper design profiles using values from a published source, I would really appreciate it!
Here’s an example of an M28x1 thread I’m working on. Calculator is METhreadPal. The sketch shows the full root radius 0.144*P and the Minor Diameter (max) used to define the thread with a driven dimension showing the Pitch Diameter to ensure it falls in the range specified.
Would you do this differently?
I call out the thread and the machine shop does the rest. They neither need nor want accurate threads in the model. The machine shop owns the proper metrology equipment to ensure the threads meet the standard.
Same here
Usually you don’t cut the thread in one pass. So cut, measure and adjust.
We cut big thread with a ball nose. So lot’s of cutting and measuring.
for those interested in it.
cheers,
Arek
Another source is here: Download
Yes, great software tool! Too bad about the author.
Thanks for the replies so far. I’ll also state that I know how to call out threads on a drawing but the intent here is to draw threads as machined. I know there are many people that do not need do this but I often combine molded and machined threaded parts and would like to understand the ‘proper’ way from a machinist’s perspective or someone who’s been bitten by doing it wrong lol.
Modelled threads are like taboo - everyone knows about it, but to model one is highly discouraged.
It is like forbidden knowledge.
Not really taboo.
More like don’t reinvent the wheel. Don’t try to make a better wheel unless you really have a really good reason to.
Repairing old press will get into odd thread and spline/gear teeth.
If I am trying to print 3d threads, I use this spreadsheet, based on the Machinery Handbook.
Thread Profile - National Standard.xls (2.9 MB)
Some online tools (no idea about how accurate the calculations are, thou)
Theoretical Machinist metric profile calculator
Machining doctor thread calculator (multiple threading standards)
‘Standard’ threads are straight-forward, it’s when you take a look at ones
used in astro-photography and equipment when the fun starts :slight_smile:
Apparently, it’s kind of a mess
I stumbled on this site just yesterday: https://www.gewindebohrer.de/en/service#technical-information
There seems to be a lot about different kinds of threads and about threading in general.
All great resources for calculating the numbers, the challenge is choosing which numbers to use for defining the sketch for both mating threads. It’s relatively easy when we’re talking about a basic thread profile but we’re not here, we’re provided ranges of min/max where you have to choose ‘a number’ when sketching. So which is the ‘driving’ dimension?
Pitch, pitch diameter and thread angle. They’re the same for Internal and external.
Minor and major diameters are cut off the sharp points and clearance.
Are these threads based on any kind of standard?
If you can get your hands on a copy of Machinerys Handbook, it goes into the math that describes an American Standard thread. I would take those equations (or similar ones for a metric thread) and apply it to whatever it is you are trying to manufacture.
Yes the spec is shown in the METhreadPal calculator window. they are ISO M28 x 1-6g
I beileve ISO 68-1 is the standard for an ISO thread.
On the rare occasion where I need to show threads for a drawing it’s only to show the length. I still call out the thread type with a note, and I never use the Part with threads in an Assembly. I use a configuration with the threads suppressed for that.
