So,
I’ve hit a roadblock in a VBA macro I’m writing to save parts for 3D printing. The macro works on the open document. If it’s a part, it saves it directly. If it’s an Assembly, it calls a recursive traversal routine.
I’m using a simple assembly traversal routine which look like this (this is just the traversal stuff, there is lot’s more going on that isn’t relevant to the conversation):
Option Explicit
Dim swAssy As ModelDoc2
Dim swConfig As Configuration
Dim swRootComp As Component2
Set swAssy = swApp.ActiveDoc
Set swConfig = swAssy.GetActiveConfiguration
Set swRootComp = swConfig.GetRootComponent3(False)
TraverseAssyComponents swRootComp
Sub TraverseAssyComponents(swParentComp As Component2)
Dim swChildren As Variant
Dim swChildComp As Component2
Dim i As Long
Dim errors as long
Dim warnings as long
Dim bReturn as boolean
Dim strFilename as string
Debug.Print swParentComp.GetPathName
swChildren = swParentComp.GetChildren
For i = 0 To UBound(swChildren)
Set swChildComp = swChildren(i)
If LCase(Right(swChildComp.GetPathName, Len(".SLDXXX"))) = LCase(".sldasm") Then
TraverseAssyComponents swChildComp
'Some handwaving here to get the strFilename in the correct configuration.....
breturn=swModel.SaveAs4(strFilename, swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_Silent, errors, warnings)
Next i
If the items referenced by swComp is a part, it saves it out as an STL. If it’s an Assembly, it calls the routine recursively. There is a function not shown that ensures things only get saved once.
As luck would have it, my assemblies have multiple copies of the same parts, albeit with different configurations. The routine as currently crafted will only print the first instance as it’'s matching only the name, not the config.
The challenge I’ve got is that I can’t for the life of me figure out a way to get config names for the referenced parts using Component2 in the subroutine.
Any thoughts about ways to do this are appreciated.
Cheers,
chris
