Traverses of assembly components. All dots over Ї
My version of the function how to correctly get all the components of an assembly from all its configurations. I get all the component data in a Dictionary with several attachments. A component here is a part or an assembly (you can add a filter if you need one).
First-level keys - These are full paths to the component model file (this is a fairly unique identifier (unsaved ones get “NotSaved[” & ModelDoc2.GetTitle & “]”, and virtual ones get the path to a temporary file in the SV-temp folder))
Second-level keys - This is the configuration of the component that occurs in the assembly (if the component has 10 configurations, and only 2 of them are used in the assembly, then only 2 will be in the dictionary).
Third-level keys are the names of the parameters: States in the Assembly, special properties, User Properties.
Values ​​- these are actually the values ​​of these properties.
I added the PrintPRP Function that displays the received properties for a given component, as well as auxiliary functions so that the entire model works at once.
*I mentioned in the comments about component states in the context of the build that you can organize a triple state for example: True, False and Zero or organize another level of complexity (Build Configuration Name)(Component Path)(Component Configuration Name)(Parameter Name){Value}
Improvements and additions are welcome.
' Macro: Extract All Components from All Configurations in an Assembly
' Description: Traverses all configurations of the top-level assembly and collects components and their configuration data.
Public ASM_CON_NAMES As Variant ' Array of configuration names
Public DIC_AllComp As Object ' Dictionary to hold all components and their configurations
Sub Main_ExtractAllComponents()
    Dim AsmConfsMgr As SldWorks.ConfigurationManager
    Dim AsmActiveConfName As String
    Dim ResolveAllAns As Integer
    Dim iASM As Long
    Set swModel = swApp.ActiveDoc
    If swModel Is Nothing Then Exit Sub
    If swModel.GetType <> swDocumentTypes_e.swDocASSEMBLY Then Exit Sub
    Set swAssy = swModel
    Set AsmConfsMgr = swModel.ConfigurationManager
    AsmActiveConfName = AsmConfsMgr.ActiveConfiguration.Name
    ASM_CON_NAMES = GetConfWithActvFirst(swAssy, AsmActiveConfName)
    ResolveAllAns = swAssy.ResolveAllLightWeightComponents(True)
    If ResolveAllAns <> 0 Then
    Select Case ResolveAllAns
        Case 1: Debug.Print "Resolution aborted by user"
        Case 2: Debug.Print "Some components could not be resolved"
        Case 3: Debug.Print "Components were not resolved"
        Case Else: Debug.Print "Resolution did not occur"
    End Select
    'Multi-level dictionary for storing properties: Key1 - full path to file, Key2 - Configuration name, "Key3" - parameter name, "Value" - parameter value.
    Set DIC_AllComp = CreateObject("Scripting.Dictionary")
    For iASM = 0 To UBound(ASM_CON_NAMES)
        If iASM > 0 Then
            If swModel.ShowConfiguration2(ASM_CON_NAMES(iASM)) Then swModel.ForceRebuild3 (True)
        Dim vComps As Variant
        vComps = swAssy.GetComponents(False)
        If IsEmpty(vComps) Then GoTo NextASMConf
        Dim iComp As Long
        For iComp = LBound(vComps) To UBound(vComps)
            Dim swMod As SldWorks.ModelDoc2
            Set swComp = vComps(iComp)
            If Not swComp Is Nothing Then
                If swComp.IsSuppressed = False Then 'If the component is not extinguished This check can be removed if it is necessary to process extinguished files **1
                    Call ProcessComp(swComp, swMod)
        Next iComp
NextASMConf:
    Next iASM
Function ProcessComp(swComInAsm As SldWorks.Component2, swComMD2 As SldWorks.ModelDoc2) As Integer
    ProcessComp = 0
    Dim Key_FilePathName As String
    Dim CompConfNames As Variant
    Set swComMD2 = swComInAsm.GetModelDoc2
    If swComMD2 Is Nothing Then Exit Function
    Key_FilePathName = swComMD2.GetPathName
    If Key_FilePathName = "" Then Key_FilePathName = "NotSaved[" & swComMD2.GetTitle & "]"
    Dim CompConfNameInAsm As String
    CompConfNameInAsm = swComInAsm.ReferencedConfiguration
'    CompConfNames = GetConfWithActvFirst(swComMD2, CompConfNameInAsm, "SM-FLAT-PATTERN")
'    If IsEmpty(CompConfNames) Then Exit Function
'    Dim iConf As Long
'    For iConf = 0 To UBound(CompConfNames)
'        If iConf > 0 Then swComMD2.ShowConfiguration2 CompConfNames(iConf)
        If DIC_AllComp.Exists(Key_FilePathName) Then
            If DIC_AllComp(Key_FilePathName).Exists(CompConfNameInAsm) Then GoTo NextConfComp
            DIC_AllComp(Key_FilePathName).Add CompConfNameInAsm, GetAllConfPrp(swComInAsm, swComMD2, CompConfNameInAsm)
        Else
            DIC_AllComp.Add Key_FilePathName, MakeConfDic(swComInAsm, swComMD2, CompConfNameInAsm)
            If Not IsEmpty(DIC_AllComp(Key_FilePathName)(CompConfNameInAsm)) Then
                If TypeName(DIC_AllComp(Key_FilePathName)(CompConfNameInAsm)) = "Dictionary" Then
                    If PrintPRP(Key_FilePathName, CompConfNameInAsm) = True Then
                        ProcessComp = ProcessComp + 1
NextConfComp:
'    Next iConf
End Function
'Function to create a nested dictionary
Function MakeConfDic(Comp2 As SldWorks.Component2, Mod2 As SldWorks.ModelDoc2, ByVal ActiveConfigurationName As String) As Object
    Dim DIC_conf As Object
    Set DIC_conf = CreateObject("Scripting.Dictionary")
    DIC_conf.Add ActiveConfigurationName, GetAllConfPrp(Comp2, Mod2, ActiveConfigurationName)
    Set MakeConfDic = DIC_conf
End Function
' Function for directly getting properties for a specific component configuration
Function GetAllConfPrp(Comp2 As SldWorks.Component2, Mod2 As SldWorks.ModelDoc2, ByVal ActiveConfigurationName As String) As Object
    Dim DIC_PRP As Object
    Set DIC_PRP = CreateObject("Scripting.Dictionary")
' Component states in the assembly (they do not exist outside the assembly context) respectively the same component can be (in different or not in different assembly configurations)
'both Virtual and non-virtual, both a converter and not a converter, therefore such obtaining of properties is not entirely correct. It will be correct to obtain: Triple state,
'for example for an Envelope: Always only NOT an envelope, Always only an envelope or can be both an envelope and not a converter. It is possible to store in which assembly configurations which states are present.
    If Not Comp2 Is Nothing Then
        DIC_PRP.Add "Component2", Comp2 'Store a reference to an object in an assembly
        DIC_PRP.Add "Name2", Comp2.Name2 'Get the name of the component in the assembly (subAssem1-2/Part1-1)
        DIC_PRP.Add "IsSuppressed", Comp2.IsSuppressed 'Suppressed or not in the Assembly (this can be left if there is no check for Suppressed files in the context of the "For iComp" cycle)**1
        DIC_PRP.Add "IsVirtual", Comp2.IsVirtual 'Virtual or not
        DIC_PRP.Add "ExcludeFromBOM", Comp2.ExcludeFromBOM 'Excluded from specification in this Build configuration
        DIC_PRP.Add "IsEnvelope", Comp2.IsEnvelope 'envelope
    Dim filename As String
    If Not Mod2 Is Nothing Then
        If DIC_PRP.Exists("IsVirtual") Then
            If DIC_PRP("IsVirtual") Then
                filename = Mod2.GetTitle
            Else
                filename = GetFileNameWithoutExtension(Mod2.GetPathName)
        Else
        DIC_PRP.Add "ModelDoc2", Mod2
        DIC_PRP.Add "FileName", filename
        DIC_PRP.Add "GetType", Mod2.GetType '1-PART; 2 - ASM
        DIC_PRP.Add "IsRollback", ISRollBack(Mod2)
        DIC_PRP.Add "ISToolboxPartType", ISToolboxPartType(Mod2)
        DIC_PRP.Add "IsSheetMetal", IsSheetMetalByGetBendState(Mod2)
        'There can be a function to read any parameters from the ActiveConfigurationName component configuration and add them to the DIC_PRP dictionary
        DIC_PRP.Add "SomePRP", "ValueOfPRP in " & ActiveConfigurationName
    Set GetAllConfPrp = DIC_PRP
End Function
'============= AUXILIARY FUNCTIONS =============================
'We find all the names of the configurations and return them in an array where ActiveConf is the first
Function GetConfWithActvFirst(Mod2 As SldWorks.ModelDoc2, FirstConfName As String, Optional NoSubStr As String = "") As Variant
    Dim swConfMgr As SldWorks.ConfigurationManager
    Dim confNameArray As Variant
    Dim activeConfName As String
    Dim confNamesList As Collection
    Dim i As Long
    Dim GoTestNoSubStr As Boolean
    confNameArray = Mod2.GetConfigurationNames
    If FirstConfName <> "" Then
        activeConfName = FirstConfName
    Else
        activeConfName = Mod2.ConfigurationManager.ActiveConfiguration.Name
    Set confNamesList = New Collection
    GoTestNoSubStr = (NoSubStr <> "")
    If GoTestNoSubStr And InStr(activeConfName, NoSubStr) > 0 Then
        confNamesList.Add ""
    Else
        confNamesList.Add activeConfName
    For i = LBound(confNameArray) To UBound(confNameArray)
        If confNameArray(i) <> activeConfName Then
            If GoTestNoSubStr = False Or InStr(confNameArray(i), NoSubStr) = 0 Then
                confNamesList.Add confNameArray(i)
    Next i
    Dim confNamesArray() As Variant
    ReDim confNamesArray(0 To confNamesList.Count - 1)
    For i = 1 To confNamesList.Count
        confNamesArray(i - 1) = confNamesList(i)
    Next i
    GetConfWithActvFirst = confNamesArray
End Function
'Authentic sheet metal
Function IsSheetMetalByGetBendState(ByVal swModel As SldWorks.ModelDoc2) As Boolean
    Dim nBendState As Long
    nBendState = swModel.GetBendState
    IsSheetMetalByGetBendState = (nBendState <> swSMBendStateNone)
End Function
'Component with tree in rollback state
Function ISRollBack(Mod2 As SldWorks.ModelDoc2) As Boolean
    Set swFeat = Mod2.FirstFeature
        If swFeat.IsRolledBack Then
            ISRollBack = True
            Exit Function
    Loop
    ISRollBack = False
End Function
'Toolbox component (not to be confused with the "IsFastener" property)
Function ISToolboxPartType(Mod2 As SldWorks.ModelDoc2) As Boolean
    Dim swModelExt As SldWorks.ModelDocExtension
    Set swModelExt = Mod2.Extension
    ISToolboxPartType = (swModelExt.ToolboxPartType <> swToolBoxPartType_e.swNotAToolboxPart)
End Function
Public Function GetFileNameWithoutExtension(ByVal path As String) As String
    If path = "" Or InStrRev(path, "\") = 0 Then
        GetFileNameWithoutExtension = ""
    Else
        GetFileNameWithoutExtension = Mid(path, InStrRev(path, "\") + 1, InStrRev(path, ".") - InStrRev(path, "\") - 1)
End Function
Function PrintPRP(ByVal Key_FilePathName As String, ByVal ConfName As String) As Boolean
    On Error Resume Next
    Dim dicPRP As Object
    Set dicPRP = DIC_AllComp(Key_FilePathName)(ConfName)
    If dicPRP Is Nothing Then Exit Function
    Debug.Print "File: " & Key_FilePathName & " | Config: " & ConfName
    Dim k
    For Each k In dicPRP.Keys
        If TypeName(dicPRP(k)) <> "Object" Then
            Debug.Print "    " & k & " = " & dicPRP(k)
    Next k
    PrintPRP = True
End Function
Hey Mr Mihkov, glad to see you on here!
