umm..
https://www.beacon-india.com/incremental-text-pattern-in-solidworks/
Thank you IDONTEXIST for posting this here:
https://www.cadforum.net/viewtopic.php?p=31596#p31596
umm..
Just stumbled on to this one after 14 years of SW usage.
Want to add something to a dimension? You donāt need to type the + symbol! You can just stick the number you want to grow it by at the end and SW figures it out.
My latest SW achievements!
Time to add something new to this thread.
My main thing to optimize has always been to reduce how many clicks I do with my right hand. The Spacemouse has definitely been a huge improvement in this regard, but it does more than just navigating. I have the simple two button model and the obvious shortcut for one of them I think, is fit to view(F), but the real smart one is OK. This way I can finish a lot of commands with my left hand on the spacemouse, especially when applying library features (something we do a lot in my company). OK is a different command than enter and as far as I can see itās not available as a shortcut otherwise.
Maybe everyone already knows this, but if you insert a centerline to a Detail View the end of the line will extend past the edge of the view (first screenshot). If that bothers you like it does me you can select it and zoom out. The end of the line will show up where it would be if the whole model was in the view (second screenshot). You can then click on it and drag it to where you want it.
By the way, you have to zoom out to see it. Fit Sheet will not do it.
I stumbled on another one yesterday. I often model relatively complex rebar in concrete, so I often have a drawing sheet of a cropped isometric view with the rebar shown in colors. I realized that if I use a sketched rectangle for the Crop outline it will snap to the lines defining the border so that the edges of the model are right on the border lines.
