mirror, linear pattern, circular pattern, mirror, linear pattern, circular pattern, mirror, linear pattern, circular pattern, mirror, linear pattern, circular pattern, mirror, linear pattern, circular pattern, mirror, linear pattern, circular pattern, mirror, linear pattern, circular pattern.
These will make your life sooooooo much easier.
it’s useful for bugged-imported-PRT, to remove some “face color”
when “remove all color” doesn’t work
but sometime the bug comes from the “imported feature” in the tree
(must apply a temporary color, to then be able to remove it)
or to count a total surface minus two or three (select all, then unselect specific)
If I recall correctly, this is what I used in the SLUGME video to quickly select all of the edges of the solid to create my weldment geometry.
(I like this method better than my old method of rt-click a face, select “invert selection”, ctrl+click to select the original face.)
t
I’ve done it to quickly select the edges to convert entities in a 3d sketch. (I learned about creating a solid body to drive a 3d sketch in a class at SW World a few years ago that was taught by Alin and one of his colleagues. See the attached file. I didn’t convert all entities in this example, but you’ll get the idea.)
It’s tricks like that you can have in your back pocket when taking the certification exams. You need as many of them as you can find, and practice problems showing you how to use them because it can save you massive amounts of time, if for example you need to select a bunch of faces.
I wont write stuff that is already written here but i use a lot of tips from this thread.
I would like to mention that i really like orienting my view as i want by clicking surface i want to see normal and selecting another surface which will be “up” from previously selected one.
To build on this, if you hold CTRL+SHIFT+TAB, it will show a ghost image of all the hidden parts and you can click them to unhide them. When you let go, it goes back to the standard view.
Also, to contribute, the feature tree can be fully expanded with * (on the numpad, not SHIFT+8) and then fully collapsed with SHIFT+C.
Use a profile center mate with 0" dim. instead of a concentric and a coincident. Saves a little bit of time and keeps things a little cleaner. I use a macro pinned to one of my mouse gestures for this. mike miller posted the macro on the “My Macros” thread (we work for the same company).
Use the “Home” and “End” keys on your keyboard, home will jump to the beginning of a line of text and end will jump to the end of a line of text.
Also when editing mates click on the component, now instead of clicking on the mate that pops up in the breadcrumbs and then clicking on edit feature and changing the properties, RMB on the mate that pops up on the breadcrumbs and then you can change various things from that menu.
