Virtual Assemblies Unopened Reference?
Hi,
I have a file I am making a virtual part, done this with a few hundred assemblies to make up a library for a vendor product line we are using.
I saved all the part and assemblies, then copy the assembly file to a specific directory.
Open the copied Assembly file in new locations, select all parts and sub-assy and make virtual including parts.
I then save and rename parts to remove the “Copy Of” as we have a PDM and file name length has become a issue in the past.
When I look at the find reference I get the following: (NTS16535)
I have deleted all the history in all the sub-assy and tried to purge the configurations in them although nothing shows up.
What am I missing?
Regards,
Jim
Is there a leftover in-context reference to that part in the assembly maybe?
Hi,
That is why I deleted the history in each sub-assembly hoping it was hung up there but still no luck.
Unless there is something else you are talking about, and if so please elaborate.
Regards,
Jim
Can you show the assembly tree?
Hi all,
I deleted all of my derived patterns and presto no more rogue links, go figure:
Solidworks 2020 sp4.0
tree:
Thanks all for the input
Regards,
Jim
