Undo Make Virtual
Undo Make Virtual
How about this one !
2026
Automatic update of cut list
Until they do make this feature… If “Make virtual” is something you rarely if ever actually want to do, you can customize your menu to take it off…
Unfortunately I use it enough to make its presence worthwhile, and it’s usually “Isolate” I’m aiming for that’s right below it.
I think I’m right in thinking the order of the right click menu can’t be changed?
Yeah, I think all you can do is enable/disable things from showing. If you’re usually shooting for Isolate, maybe you could map Isolate to a keyboard shortcut?
It looks like you can’t directly put it on the S-key menu or the in-context popup menu, which is weird. But this macro is exactly the same thing as clicking “Isolate” in the right-click menu. You could then put a button on either menu to run this macro.
    Application.SldWorks.RunCommand swCommands_Comp_Isolate, "Why is there no button for this?"
Neat, thanks!
when you right click there is a keyboard shortcut on that menu for Isolate by hitting the “I” already. Instead of reading the whole list every time I want to show just a few parts I use this because the right click list of commands can be long and to much there now days.
That’s a good point… I use a couple of those myself! Although they are a bit subject to change depending on context. I used to use RMB-S for Select Other, but in some contexts RMB-S was something else.
Thank you! I learned something new today! (I don’t know why I never noticed those underline letters in the right click menu before!) I have used those shortcuts in other programs I guess I never checked SW.
