CADmunity
Top PDM 2026
SOLIDWORKS
SolidWorks PDM
jcapriotti
January 8, 2026, 8:51pm
1
Thought I’d breakout the Top PDM enhancements voting list
Rank
Item
Votes
1
Dark Mode for PDM in Windows Explorer
40
2
PDM - API for Branch and Merge command
37
3
Centralized Materials & Coatings Management in PDM: Empower Teams, Eliminate Chaos
34
4
SOLIDWORKS PDM - Automatic Login Group and User Controlled
28
5
PDM: Allow Task List access from vault
18
6
PDM: Log copied source file in destination file’s history
17
7
PDM: Better task host routing for tasks
16
8
PDM: Increase/remove task script character limit
16
9
PDM: Replace old Data Card with web based tools
12
10
SW PDM Paste as reference, show in BOM: ability to choose the configuration in which the reference is shown in the BOM.
12
11
You don’t have permission to perform this action (Checkout, Get): Lack of clarity of the reference causing the error
10
12
In PDM explorer, anchor/dock the separator to the bottom of the window.
10
13
PDM Data Cards: Restrict Edit / Read-Only Access on a control by user/group permission
10
14
PDM: Add file type filters in contains, where used, check-in dialogues.
9
15
SOLIDWORKS PDM: Easier Access to Task List
8
16
Possibilities Set default tabs in PDM Explorer
6
17
PDM: Input formula should calculate for all configuration tabs.
6
18
PDM: Allow for “Select child references during state change” to be set per transition
6
19
SOLIDWORKS PDM - Manual Login Should Dismiss Other Active Dialogs
4
20
SOLIDWORKS PDM - Login As Other User
4
21
PDM - private state notifications
4
22
PDM - add dynamic recipients to delayed in state notifications
4
23
SOLIDWORKS PDM: Inline Bill of Materials Search inside the BOM tab (replace modal dialog)
4
24
PDM: Add “Display Value” option to variables.
4
25
PDM: Addition to Transition Conditions: Group Membership
4
26
PDM: Enhance configuration handling and UI in data card.
3
27
Smart Revision Control Inside SOLIDWORKS
1
