Title block issues
Maybe someone can tell me if my title block is pulling the wrong information.
Before I explain, I think all sheets of a drawing should have the same title/description. There are some I work with that think otherwise.
Here is what’s happening.
I have a title block set up to pull the configuration name/description/rev from the part/assembly file.
When the sheet is copied to create a multi sheet drawing, the parent view configuration is change but the title block does not change.
EX: I have a part “TOP” with 2 configurations: “TOP-LAMINATE” & “TOP-GLASS”
I would like Sheet1 to read “TOP-LAMINATE” and Sheet2 to read “TOP-GLASS”
Am I pulling the incorrect information for this to happen?
Do you have this checked on your template settings? (SW2022 SP4)
NO. That check box is cleared.
You’ll want to edit your Sheet2 properties and un-check this box and change the reference drawing view to the parent one on the current page you want to use.
