SW PDM standard license
I have both SW and SWPDM server upgraded to 2022
Tried to login the Vault and got the err - see att. image
Any idea what it is
Thanks
Did you select the correct options on install? I think by default it install PDM pro. I remember having to make explicit choices to get PDM standard instead of Pro, but I can’t provide any specifics without going through the install process.
Yes, I selected “standard” when installing it
christian chu Did you update the license manager server software to 2022?
Along the same theme, did you upgrade your SQL database with the upgrade tool? There’s a fair bit of configuration that needs to be done to the database side in order to make it compatible with all the new features of a PDM upgrade. Although, I can’t remember if it would let you connect to the vault if the versions don’t match.
yes, I used this help link
https://support.hawkridgesys.com/hc/en-us/articles/4407527527309-How-To-Upgrade-The-PDM-Server-2022#_Toc19890589
I got error mesg while upgrading the license manager
christian chu Did you move it to another server?
no
