SW note convert Autocad note
Hi Guys,
The notes you write in sw always turn into the same font in autocad.
Is there any way to prevent this?
Hi, I don’t seem to get this problem.
See below in SW
And Autocad/TruView
These are the settings I use to export under system options. I am using SW2019.
Don’t know if this helps you at all.
Thanks a lot Shaun
I’m marking your answer as correct since you answered before me.
Thank you again.
Actually I found the answer here (Rob E. showed)
https://help.solidworks.com/2017/English/SolidWorks/sldworks/HIDD_EXPORT_OPTION_DXF.htm
