So I did a few notes connecting them to dims and that worked fine. I updated one of the holes and the dimension went wacko. So I went back and tried to fix it…and it’s just completely broke.
It will not let me delete the first line of the dim as shown in the attached video. I’ve deleted all the related dimensions, shut down SW etc. I have not rebooted because if I do I know I will not turn the damn thing back on and I will just go home
This makes zero sense to me and I’ve been running into little stuff like this all day.
I sent the GD & T issue to my VAR and got a “I see what your experiencing I will have to research it”. I really can’t complain though my VAR support has been exceptional. I’m sure they will research it…and find that SW is just broke…again.
Some days are worse than others. You get used to expecting something often. Some days however it seems everything you do just doesn’t work right or the way you think it should and you spend most of the day “figuring it out”. Usually this happens on days when you are trying to get something done quickly and or you are behind
FWIW I figured out the GD&T issue. The boxes perform as one would expect if you place them with no leader and attach them to a dimension rather than the geometry.
I love the fact that by stating this to the world you have just guaranteed yourself of at least a week of SW living hell
I once had a co-worker send me his Rx that showed how many times SW had crashed for him in the last week. I made the mistake of gloating and sending him mine which showed I had not crashed more than once or twice all week. With in the hour my SW crashed like three times in a row…I’ll never make that mistake again
This has happened to me before. Generally on holes that are not directly from the hole wizard, but imported through some other process (like pattern, or insert part, etc…).
This pisses me off when it happens. Sometimes it will fix it if I replace the dimension…sometimes I have to fudge it with a note that is linked to a standard dimension instead of a hole callout.
