Specify / Swap DRWDOT template
Lets say I constructed a drawing which was made from template A.drwdot. I have another template B.drwdot. Is there a way to just specify B.drwdot within the ‘A’ based drawing & save that as a new drawing without recreating the whole thing specifying B.drwdot from the onset? I could see this might blow up if the templates were substantially different so maybe not even an option. Maybe another scenario is A.drwdot got deleted & some poor soul is facing a bunch of drawings that need to be connected to an new drawing template.
There are many macros available, using which you can replace the sheet format from A to B. Search on the forums under API or Macros sections, and you will find them.
Please note that once a drawing is created, it is no longer connected to the original DRWDOT file. You can only change/update the sheet format, but that has to be done manually or via some scripts.
if the A.drwdot got deleted it would be easy to open one of the drawings created with it and save it as the a.drwdot. If it is needed.
When I make templates I will usually copy the title block info from the b to the c and d. A’s are sometimes special in their layout but if they are simular enough it can be done too.
Thanks for the replies. I think I understand. An existing drawing is really just a ‘save as’ step away from becoming a corresponding template by saving it as .drwdot? The views layout, title block, font etc. are all preserved. Or maybe if you want a slight modification, its maybe more efficient to start with a drawing that exists, turn it into a template & modify a bit vs building the whole template from scratch. Is that the general idea? I will check into macros, I know enough to be dangerous.
Yes… A template is nothing but a blank starter file. You would get basically the exact same result by just saving a regular .slddrw and starting every drawing by opening the .slddrw and adding views.
