Solidworks Visualize 2025 - workaround for unsupported graphics cards?
Using Solidworks Visualize Standard 2025 as part of a Professional installation on my home machine, which I built myself. Everything runs fine, except for trying to use AMD prorender in Visualize. It results in an all-black model. When I run in preview mode, I can see the model just fine, but turning on “accurate” in the viewport or rendering to a file results in the all-black output unless I choose “preview” in the renderer selection.
I am aware that my graphics card is unsupported. I am also aware that this card kind of sucks. Using Visualize is less than 1% of my work, and I also use this machine for gaming and personal projects. It just seems like a shame that I can’t get high-quality renderings when every other aspect of SolidWorks behaves perfectly fine.
Is there a workaround for this? I’m aware of the registry hack to enable RealView in Solidworks. Hopefully there’s some way to get my card working with Visualize, too. If not, I’m open to returning the card for something that rips through games and also works with Visualize.
System specs:
AMD Ryzen 7 5800X
AMD Radeon RX 7600
64 GB RAM
See if the recommendations here help:
https://www.reddit.com/r/SolidWorks/comments/z369if/solidworks_visualize_with_nonworkstation_gpu/
That thread has recommendations for NVIDIA GPUs. Nonetheless I tried adding Visualize to AMD Adrenalin and forcing the Windows setting, and it still didn’t work.
Sorry about that. This link references the Radeon Pro.
Amazing - thank you!! The secret sauce was to force a download of Radeon Pro software by lying to AMD’s website saying I was looking for drivers for a workstation card. The RX 7600 enjoys limited support in Radeon Pro, but it’s enough!!
Edit: it’s hit or miss. Some rendering settings work, others hang up on “Calculating…”.
