I currently use Solidworks 2023 and I would like to explore Solid Edge as a possible alternative, so I have downloaded the community edition and I am playing a bit with it.
I have a background of UG/NX and some mechanics seems similar in Solid edge 2025, at first glance. At my place we use a lot of weldments in Solidworks and the equivalent in solid edge seems a bit too complex in comparison (or solidworks made it quite easy with its multibody approach).
Wondering if anyone has a simple tutorial that covers weldments topic well or some resources with standard profiles and ready to use setup.
Many youtube videos seem quite old and the SE interface looks like to have been quite renewed recently.
Thank you.
I am used to Solidworks weldments, which in comparison is a bit simpler to work with.
Just a basic question: in solidedge the frame is handled as an assy, but it seems its beam components are internal to the assy file, and hard linking to the library profiles. You basically need the same library and the assy file alone to be able to open the frame on another workstation. is this correct?
SE Frame works the same way as SW weldments except you draw the 2d, 3d sketches in the assembly file. Because the frame is drawn in the assembly file, it is much easier to add sheet metal parts to the frame and bought out parts to the frame and show it in the parts list on the drawing.
