An upgrade this weekend has slightly broken the site. If you access the site at https://forum.cadmunity.com everything should be working normally. If you try to use https://www.cadmunity.com or https://cadmunity.com you will receive an error stating Invalid SSL certificate. The certificate isn’t actually invalid, it just isn’t correctly pointing at those domain names. As soon as it is fixed, I’ll send out another announcement.
