Thanks Frederick, sorry for the delayed reply… I wanted to first wrap up my initial ‘exposure’ to linear(matrix) algebra, solid/continuum mechanics, and FEA basics* as well as Simulation so I could contribute some useful information.
- Thanks to U.of Alberta Prof. Clayton Pettit’s online lectures(downloadable with apps) on YouTube!!! His lecture/seminar videos are better than the “OOO for Dummies” series. For those grossed out by 6X6+ matrices, integrals, partial derivatives etc. his lectures are the bomb - demystifies all the fancy geek gibberish.
As you mentioned, SW Simulation treats joints by default as ‘Bonded’ but apparently can be user defined - i.e. changeable to ‘Contact’(No Penetration), or ‘Free’(Allow Penetration).
Aside from the Weld Bead feature in SW (not applicable in Simulation), in SW Simulation, there is the ‘Edge Weld Connector’ (under ‘Connections’ along with Spring, Pin, Bolt, Bearing, … etc.)
*Note: ‘Connectors’ are “virtual” meaning ‘no (real) geometry’, hence no stress calculations or data result, but data regarding loads/forces transferred through them ARE analyzed) which allows analysis & determination of weld bead size based on user defined parameters such as electrode(welding rod) type, applied loads, estimated bead size, Factor of Safety etc.
It is amazing that “Weld Check Plot” in Simulation will show if a weld bead “Needs attention”(in size) or if it is “OK” based on comparison between the user’s “Estimated” bead size vs the analysis determined ‘required minimal bead size’ !
Further, within Weld Check Plot > “Details”, forces acting on the joint (i.e. Joint Normal Force, Shear-Weld axis force, Shear-Surface normal force, Bending moment, etc. ) can be viewed, and “Report Options” > “Plot” will display a graph of the required “Weld size”(leg length) and “Weld throat size”(depth from root to face).
As a SW rep mentioned in a seminar, it may be better though to initially do simulations without the Edge Weld Connector, and just utilize the default ‘Bonded’ feature for initial analysis data as the joint edge data will not be affected by idealized weld beads between the parent materials.
I think I will do both - first without Edge Weld Connector, then with the Edge Weld Connector activated for all joints, for comparative analysis.
For Simulation analysis with weld beads as the ONLY joining method (i.e. ‘Bonded’ Connection feature disabled), the following setup is possible;
- Under Connections > Component Interactions > Global Interaction(Contact) > Edit Definitions,
1.) Change the Interaction Type from ‘Bonded’ to ‘Contact’(No Penetration)
2.) Set Properties > Gap range to consider contact > set gap dimension for inclusion of surfaces with gaps.
*** Important Note:** Tube/Pipe members generated with Weldments - Structural Member feature are recognized in Simulation (initially by default) as ‘Beams’ and their outer faces are NOT ‘select-ready’ as is (for application of the Edge Weld Connector features → a pop-up message will alert that the Edge Weld Connector feature can only be applied to faces of actual ‘solid’ models or ‘shell surfaces’. ).
Therefore, within Simulation the relevant tube/pipe (marked “SolidBody#…” under Cut-List) needs to be ‘converted’ to be ‘treated as a Solid’ then the outer face needs to be set with Shell properties before Edge Weld Connector can be applied (note steps below);
1.) In Simulation, under the Part folder > Cut list > Cut-List-Item (# of the member) > “SolidBody #…”(pertaining to the member);
2.) Right click the “SolidBody #…” > select “Treat as Solid”
3.) Right click the “SolidBody #…” > Shell Manager > in Properties window, select the outer face(to apply “Shell”) > below, Select “Thin”(or “Thick”) > for Thickness enter the tube’s thickness/units.
Now the Edge Weld Connector features can be applied to the tube(s) generated with Weldments - Structural Member feature. One might ask then why bother with Weldments - Structural Member feature at all(?), well that is because during the design phase in which dimensions of a frame can be changed frequently, it is much easier to work with sketch lines and auto trim(miter) than generating 3D tubes each time manually when dimensions & angles need adjustment.
Sorry for the long winded reply… 'hope this helps some folks!
And as you mentioned, simplified parts significantly reduce wait time for FEA.
Cheers~!
