Do you use Simple Hole feature?
- Never. We always use HoleWizard feature to create even a Simple Hole
- Yes. Whenever we require to create it.
- In some special cases. (Please explain if possible).
0
voters
I created a simple hole on a face of a block. I then created a dimension from an edge of the face to the center of the simple hole.
But the dimensions does not show in the Equation Manager.
Is this normal behavior? I am not a regular user of SolidWorks, so am I missing something?
Also, do you use simple hole feature or you just use Hole Wizard to create even a simple hole? Just curious to know!
Thanks in advance for your responses.
- NirVidP
