Sheet Metal Flat Pattern Calculator_V4_R6
Hi Guys,
I created my own calculation application. There are no problems in SolidWorks, but when I use AutoCAD, calculating the unfolding with the calculator or changing the unfolding of a previously made drawing can be complicated. I wanted to simplify this.
The K-factor values ​​(elongation values) are from a list I created based on my experiences and knowledge gained from production at the company I’ve worked for for 10 years. I value your opinions to understand the errors and try to improve it. This is purely for my personal needs, an individual effort to reduce errors and shorten drawing times. You can modify this HTML file as you wish if you think it will be useful. I chose HTML because there are no loading problems, it doesn’t show differences from PC to PC, it’s practical to use, and I can use it on my mobile phone when I go to the production area in the factory.
The zip file contains only a 40kb HTML page.
I await your advice and comments.
Remember, this HTML is not for commercial purposes, company requests, or to make any claims; it’s simply to meet my personal needs and speed up the process a little.
Sheet Metal Flat Pattern Calculator_V4_R6.zip (11.0 KB)
Very cool Omur, nice work!
