Save Drawing to PDF Macro assistance needed
Hello all,
I have a Macro that I found online for saving drawings as PDF files. There are two items that this does that I would like to change but I do not know if these are code problems or SolidWorks settings issues. The code will be attached below and was written by Blue Byte Systems Inc. I have reached out to them with the same questions but have not received a reply as of yet.
Now to my questions. I added appearance colors to my parts and have this color carried through to my drawings. When this Macro it will take my Sheet Metal Flat Pattern to a black line drawing for that view only. I do not have this happen if I used the CutePDF writer that is installed on my computer.
This Macro also creates Bookmarks in the PDF drawing. These are not needed. If someone could help me solve this I would appreciate it.
Code is below;
Dim swApp As Object
' Disclaimer:
' The code provided should be used at your own risk.
' Blue Byte Systems Inc. assumes no responsibility for any issues or damages that may arise from using or modifying this code.
' For more information, visit [Blue Byte Systems Inc.](https://bluebyte.biz).
Option Explicit
' Main subroutine to save the active drawing as a PDF file
    ' Declare and initialize necessary SolidWorks objects
    Dim swApp As SldWorks.SldWorks             ' SolidWorks application object
    Dim swModel As SldWorks.ModelDoc2          ' Active document object (drawing)
    Dim swModelDocExt As SldWorks.ModelDocExtension ' Document extension object for saving operations
    Dim swExportData As SldWorks.ExportPdfData ' PDF export data object
    Dim boolstatus As Boolean                  ' Boolean status to capture operation results
    Dim filename As String                     ' String to hold the file path of the drawing
    Dim lErrors As Long                        ' Error variable for save operation
    Dim lWarnings As Long                      ' Warning variable for save operation
    ' Initialize SolidWorks application and get the active document
    Set swModel = swApp.ActiveDoc
    ' Check if there is an active document open
    If swModel Is Nothing Then
        MsgBox "No current document. Please open a drawing and try again.", vbCritical, "No Active Document"
        End
    ' Check if the active document is a drawing
    If swModel.GetType <> swDocDRAWING Then
        MsgBox "This macro only works on drawings. Please open a drawing and try again.", vbCritical, "Invalid Document Type"
        End
    ' Get the document extension object for saving operations
    ' Get the export PDF data object to specify PDF export options
    Set swExportData = swApp.GetExportFileData(swExportPdfData)
    ' Get the file path of the active drawing
    filename = swModel.GetPathName
    ' Check if the drawing has been saved previously (it must have a valid file path)
    If filename = "" Then
        MsgBox "Please save the file first and try again.", vbCritical, "File Not Saved"
        End
    ' Generate the PDF file path by changing the file extension to .PDF
    filename = Strings.Left(filename, Len(filename) - 6) & "PDF"
    ' Set the export option to include all sheets in the PDF file
    boolstatus = swExportData.SetSheets(swExportData_ExportAllSheets, 1)
    ' Save the drawing as a PDF file using the specified filename and options
    boolstatus = swModelDocExt.SaveAs(filename, 0, 0, swExportData, lErrors, lWarnings)
    ' Check if the save operation was successful and display a message box
    If boolstatus Then
        MsgBox "Save as PDF successful!" & vbNewLine & filename, vbInformation, "Save Successful"
    Else
        MsgBox "Save as PDF failed. Error code: " & lErrors, vbExclamation, "Save Failed"
To remove the bookmarks, you have to tweak a system setting:
swApp.SetUserPreferenceToggle swPdfIncludeBookmarks, 0
If you (and everyone who uses your macro) never wants bookmarks, even when saving manually from SW, just add that line right after Set swApp = Application.SldWorks
It’s equivalent to checking this box:
If you want to tweak the setting only during the macro run, then you will want to store the current setting at the start, change it while the macro does its thing, and then restore it at the end
Dim currentSetting as Integer
currentSetting = swApp.GetUserPreferenceToggle(swPdfIncludeBookmarks)
swApp.SetUserPreferenceToggle swPdfIncludeBookmarks, currentSetting
Jim,
Thank you for the help regarding the Bookmarks. hopefully someone will be able to help with the flat pattern color problem.
David
Are you adding appearances to the part, bodies inside the part or faces of the part?
Are your drawings using shaded views?
Are you saying that the flat pattern view in the drawing is showing up as non-shaded? Like this:
The macro isn’t doing anything more than performing a Save As. Have you tried doing a Save As PDF manually from inside SW to see if the problem occurs there as well?
M12241 00104C.PDF (84.8 KB)
M12241 00104Ca.PDF (84.8 KB)
M12241 00104C.SLDDRW (255.8 KB)
M12241 00104C.SLDPRT (192.5 KB)
Jim,
I had not tried that until you asked. I get the same results either way. I have attached a PDF file created both ways showing the same result. The PDF that ends in a was done as a save as the other one with the Macro. I have also attached a drawing and a part file to this. I was not able to attach the assembly file. I expect views to be empty if you try to open the drawing. I am applying colors at the part level. I do not know why I am only having the color issue with Flat Pattern views. I do not know what setting may need to be changed.
I think it is possible that the flat pattern colors are controlled by document properties.
I can replicate the issue. Interestingly, it may have nothing to do with the fact that it’s a flat pattern. Rather, it has to do with the fact that your drawing includes views of the assembly model and of a part model from the assembly. The problem goes away if you eliminate the part model and have an assembly configuration that shows the flat pattern. Unfortunately, you then don’t get the bend lines. I’m out of time for today, but I’ll look a little more closely tomorrow.
Mr. Perman,
I will look into this. How did you get the table at the bottom of the help page you linked me to. Is that part of future version help files. Currently running 2020 here due to lack of computer upgrades. Second work station we had could not handle anything newer.
Jim,
I appreciate the time you have spent on this for me. I just tested your observation with a part that has no assembly file associated with it, it was jus a sheet metal part with a single bend and I had the same result. The flat pattern view changed from red in the SolidWorks Drawing to black in the saved PDF file.
Are you settings toggled to save in black and white? :sweat_smile:
That link is to 2024, but that feature was available in 2020 also.
This is determined by this setting:
Bug/conflict with the setting you are using “Use model color for HLR/HLV in drawings”. Seems to ignore the sheet metal specific color option in the above pic but does honor it on export to PDF.
We always use the same color for model edges (black), otherwise you would have to be very selective in what colors you use in your model so that it contrasts with the sheet background color.
Mr. Perman,
I realized the difference. I have always look in the Solidworks Help not the API Help.
ALex,
If you are referring to the PDF export settings they are set for color.
Yes that’s what I was refering to. Are you ‘saving as PDF’, or ‘Printing as PDF’, also..? Some people get mixed up between both.
Alex,
I had been doing a print to PDF using Cute PDF writer. I found the Macro and used it a couple times before I realized it had the issues I am trying to get resolved.
I appreciate the assistance from those that offered. I sent this to my VAR to see what they had to say. The response from them was to change the Display Style for that view to Draft Quality. I did that and Save As works like I want it to.
** :clap:** This was the solution to one part of the problem in my post.
Do yourself a favor and purchase SharpTask. It has prebuilt macros for various SolidWorks tasks including saving files to PDF. It works way better than Task Scheduler.
