I have a macro that I run on drawings. It gets the properties of the parent model and adds that info to the file name before saving it as a PDF. This works great if the parent model is a part. If it is an assembly, it does not get the custom properties.
There is a similar post on the other site without any resolution.
https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/#community:yUw32GbYTEqKdgY7-jbZPg/iquestion:HSiHFtMuTKCsTREr_tnBNA/media:4NktlQbmQie2PsojEvtMIw
Dim Part As Object
Dim longstatus As Long
Dim swView As SldWorks.View
Dim swModelDocExt As ModelDocExtension
Dim swCustPropMgr As CustomPropertyManager
Dim sModelName As String
Dim sModelPath As String
Dim sNewPath As String
Dim sNewName As String
Dim sModelFullName As String
Dim CropPos As Integer
Dim sRev As String
Dim sDesc As String
Dim Bool As Boolean
Dim Junk As String
Set swDraw = swApp.ActiveDoc
Set swView = swDraw.GetFirstView 'this gets the sheet
Set swView = swView.GetNextView 'this gets the first view
'Set Part = swApp.ActiveDoc
Set swModel = swView.ReferencedDocument
Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
'this is the full name and path
sModelPath = swModel.GetPathName
'get filename from full path
CropPos = InStrRev(sModelPath, "\")
sNewName = Right(sModelPath, (Len(sModelPath) - CropPos))
'strip slddrw extension
sNewName = Left(sNewName, Len(sNewName) - 7)
'add revision and description
Set swCustProp = swModelDocExt.CustomPropertyManager("")
Bool = swCustProp.Get4("Revision", False, sRev, Junk)
Bool = swCustProp.Get4("Long Name", False, sDesc, Junk)
sNewName = sNewName + "-" + sRev + "-" + sDesc
sNewName = StripOut(sNewName, ",")
'add pdf extension
sNewName = sNewName + ".pdf"
'get path
sNewPath = Left(sModelPath, CropPos - 1)
'remove subdirectory from path
CropPos = InStrRev(sNewPath, "\")
sNewPath = Left(sNewPath, CropPos)
'add drawings folder
sNewPath = sNewPath + "drawings\"
sModelFullName = sNewPath + sNewName
' Save As
longstatus = swDraw.SaveAs3(sModelFullName, 0, 2)
