Right Click Customize Menu?
HI all,
Maybe another quirk of 2024, but is there a reason I right click get a customize menu button and only after that do I get the menu to clear selection or delete?
Is there a way to go directly to the clear selection/delete menu?
Very similar to the annoying windows 11, 2 menus to get to the SolidWorks rename/pack and go menu, although found a fix for that finally.
REgards,
Jim
I’m not seeing it on 2024 SP 5.0. Can you report this to your VAR?
Otherwise try the registry reset method, but make sure to take a back up first.
Hi again,
sorry forgot to mention on 2024 SP3.1, companies choice, but came from 2022 and it’s one of those annoyances, as no reason to have to go thru a nothing menu to get to the one that actually does something.
Regards,
Jim
2024 sp.5 as soon as I right click there it gives me the choice to clear selections. If I pick the hidden body then I get the choice to Delete or clear selections right away on the right click.
Any chance you can upgrade to SP 5.0?
Hi,
Companies decision on which version, would be nice if they did.
Regards,
Jim
