Dears,
I’m begining my studies of SOLIDWORKS API.
I’d like to ask your help to know if it is possible create a API to report each name of every dimensions in 2D drawing. The goal is create a proccedure to check if all necessary dimensions in an 2D Drawings was created correctly by an engineer. So i would have a standard drawing with all dimensions placed and i would run an API to compare these drawings and report if one dimension was missing.
Example: API would ckeck if dimensions H and L was inserted in this drawing comparing with other standard drawing.
