I need to replace the sheet format on a bunch of part drawings. I searched about best ways to do this and found a neat method using design checker as seen in this link:
https://www.cati.com/blog/using-solidworks-design-checker-to-change-sheet-formats/
However when I do this, it loads the new sheet format buts unchecks the “Display sheet format” checkbox in the sheet properties dialog box. This creates an extra step.
I then thought I could try the macro route and tried recording my own as well as implementing a few different ones found online with the same result.
Could something be wrong with my sheet format since the same behavior happens with either method?
I think that the macro route could work using the SheetFormatVisible Property but I haven’t had success getting it to work in the codestack macro below. Any help would be greatly appreciated.
https://www.codestack.net/solidworks-api/document/drawing/replace-sheet-format/
https://help.solidworks.com/2022/English/api/sldworksapi/SolidWorks.Interop.sldworks~SolidWorks.Interop.sldworks.ISheet~SheetFormatVisible.html?verRedirect=1
