Pressure cannot be applied to beams
Hi all,
I am trying to do a static simulation on a bracket assembly to pull 1500 lbs.
One of my parts is a C-Channel and when I try to apply pressure to the inside face it gives me a error even if I select the face and a reference geometry. Pressure Cannot Be Applied to Beams
I even tried to add a cut so the face was perpendicular to the pressure direction and still same error.
So what am I doing wrong?
Regards,
Jim
Is your C channel created using weldments or structured systems?
Weldment profile bodies are treated as beams by default (note the beam icon):
You can right click the item and tell Simulation to treat it as a solid.
Hi,
Yes it was created by the weld Structural Profiles.
I will have to try that in another study, didn’t know that was a option.
Regards,
Jim
HI,
Yes that worked, thanks for the tip
Regards,
Jim
