I have a SQL script that runs each day that sends an email to users that have files checked out greater than 3 days. If you use this as shown below you will need to create a new table to log when emails are sent. Mine is listed as reporting.dbo.EmailsDelivered below.
Email Checked Out Summary
This script looks for checked out files in PDM that have been checked out for a set amount of days
and emails a list with the location and description to each user.
Created by Jamey Evans 07/11/2022
DECLARE
@MailProfile NVARCHAR(MAX),
@EmailSubject NVARCHAR(MAX),
@DescriptionVariableID DECIMAL,
@ConfigurationID DECIMAL,
@vault NVARCHAR(MAX),
@MinDays int;
– Customisation
– Database
SET @vault = ‘’
USE [your vault database]
– Mail Profile
SET @MailProfile = ‘SolidWorks_Email_Send’;
– Description VariableID - this is the variable ID (from the “Variables”
– table) that will populate the Description column
SET @DescriptionVariableID = 49;
– Default configurationID - the description must be pulled from a specific configuration
SET @ConfigurationID = 2;
– Min number of days file has been checked out
SET @MinDays = 3;
– For summary query
DECLARE
@Name NVARCHAR(MAX),
@Email NVARCHAR(MAX),
@UserID DECIMAL,
@CO DECIMAL,
@PS DECIMAL,
@T DECIMAL,
@OldestCheckoutDate DATETIME,
@NewestCheckoutDate DATETIME,
@LastEmailDate DATETIME,
@SendEmail BIT;
– For detail query
DECLARE
@Filename NVARCHAR(MAX),
@Folder NVARCHAR(MAX),
@Description NVARCHAR(MAX),
@PrivateState BIT,
@DaysCheckedOut NVARCHAR(MAX),
@LockDomain NVARCHAR(MAX);
DECLARE
@emailbody NVARCHAR(MAX);
DROP TABLE IF EXISTS #Summary;
CREATE TABLE #Summary
name NVARCHAR(MAX),
email NVARCHAR(MAX),
userID DECIMAL,
checkedOut DECIMAL,
privateState DECIMAL,
total DECIMAL,
oldestCheckoutDate DATETIME,
newestCheckoutDate DATETIME,
lastEmailDate DATETIME,
ID int
DROP TABLE IF EXISTS #Details;
CREATE TABLE #Details
userID INT,
lockDomain NVARCHAR(255),
[fileName] NVARCHAR(MAX),
folder NVARCHAR(MAX),
descr NVARCHAR(MAX),
privateState BIT,
daysCheckedOut INT,
tableID BIGINT
DROP TABLE IF EXISTS #IndividualDetails;
CREATE TABLE #IndividualDetails
privateState BIT,
daysCheckedOut NVARCHAR(MAX),
ID INT
INSERT INTO #Summary
SELECT
CASE WHEN CHARINDEX(‘,’, U.FullName) > 0 THEN SUBSTRING(U.FullName, CHARINDEX(‘,’, U.FullName)+2, LEN(U.FullName) - CHARINDEX(‘,’, U.FullName)-1)
ELSE SUBSTRING(U.FullName, 1, CHARINDEX(’ ', U.FullName)) END AS ‘Name’,
U.[Email],
U.[UserID],
Count([DocTypeID]) AS ‘Checked Out’,
Count() - Count([DocTypeID]) AS ‘Private State’,
Count() AS ‘Total’,
MIN(D.lockdate) AS OldestCheckOutDate,
MAX(D.lockdate) AS NewestCheckOutDate,
E.LastEmailDate,
ROW_NUMBER() OVER (ORDER BY U.UserID) as ID
FROM [Documents] AS D
JOIN [Users] AS U ON U.[UserID] = D.[UserID]
LEFT JOIN reporting.dbo.EmailsDelivered E ON E.UserID = D.UserID
WHERE D.[Deleted] = 0 and D.[UserID] <> 1 AND D.[ObjectTypeID] = 1 AND DATEDIFF(DAY, D.lockdate, GETDATE()) > @MinDays
GROUP BY U.Email, U.FullName, U.UserID, E.LastEmailDate;
– Get Detail Data
INSERT INTO #Details (userID, lockDomain, fileName, folder, descr, privateState, daysCheckedOut, tableID)
SELECT
Q.UserID,
Q.LockDomain,
Q.Filename,
P.Path AS ‘folder’,
VV2.ValueText AS ‘description’,
Q.PrivateState,
Q.DaysCheckedOut,
ROW_NUMBER() OVER (ORDER BY Q.UserID) AS tableID
FROM (
SELECT
D.DocumentID,
D.UserID,
D.Filename,
D.LockDomain,
CAST(COALESCE(DATEDIFF(DAY, D.LockDate, GETDATE()), 0) AS INT) AS ‘DaysCheckedOut’,
MAX(VV.RevisionNo) AS ‘MaxRev’,
CAST (
CASE
WHEN D.DocTypeID is null
THEN 1
ELSE 0
END AS BIT) AS ‘PrivateState’
LEFT OUTER JOIN [VariableValue] as VV
ON VV.DocumentID = D.DocumentID
AND VV.[VariableID] = @DescriptionVariableID
AND VV.[ConfigurationID] = @ConfigurationID
WHERE
D.[Deleted] = 0
AND D.ObjectTypeID = 1
–AND D.[UserID] = @UserID
AND DATEDIFF(DAY, D.LockDate, GETDATE()) > @MinDays
GROUP BY
D.DocumentID,
D.[Filename],
D.DocTypeID,
D.LockDate,
D.LockDate,
D.UserID,
D.LockDomain
) AS Q
INNER JOIN #Summary S on S.userID = Q.UserID
JOIN [DocumentsInProjects] AS DiP
ON DiP.DocumentID = Q.DocumentID
JOIN [Projects] AS P
ON P.ProjectID = DiP.ProjectID
LEFT OUTER JOIN [VariableValue] AS VV2
ON VV2.DocumentID = Q.DocumentID
AND VV2.ConfigurationID = @ConfigurationID
AND VV2.VariableID = @DescriptionVariableID
AND VV2.RevisionNo = Q.MaxRev;
– Temp for testing
–SELECT * FROM #Summary ORDER BY ID asc;
–SELECT * FROM #Details ORDER BY tableID asc;
DECLARE @SummaryRows INT = (SELECT COUNT(*) FROM #Summary), @i INT = 1, @DetailRows INT, @j INT = 1;
WHILE @i <= @SummaryRows
BEGIN
SELECT @Name=[name], @Email=email, @UserID=userID, @CO=checkedOut, @PS=privateState,
@T=total, @OldestCheckoutDate=oldestCheckoutDate, @NewestCheckoutDate=NewestCheckoutDate, @LastEmailDate=lastEmailDate
FROM #Summary
WHERE ID = @i;
– Check if we should send email or not
– Send email after 3 days then send another at 5 days; Send daily after 10 days
SET @SendEmail = 0;
IF coalesce(@LastEmailDate, ‘2000-01-01’) < @OldestCheckoutDate
BEGIN
SET @SendEmail = 1;
END;
– if files have been checked out >= 10 days then send email every day
IF DATEDIFF(DAY, @OldestCheckoutDate, GETDATE()) >= 10 AND @SendEmail = 0
BEGIN
SET @SendEmail = 1;
END;
– Otherwise if it has been 5 days since we sent the last email then send email
IF DATEDIFF(DAY, @LastEmailDate, GETDATE()) >= 5 AND @SendEmail = 0
BEGIN
SET @SendEmail = 1;
END;
IF @SendEmail = 1
BEGIN – Begin IF @SendEmail
– Summary operations
– Set email body
IF(@Description is null)
SET @Description = ‘-’;
SET @emailbody = '
