I have remade our templates in sw2025, but I have a problem managing the default part template appearance.
the appearance tab is initially empty and the top node of the feature tree has a gray circle icon.
I apply a material to the part and the circle switches to the material color.
That is ok.
When I create a simple extrusion a gray color is applied to it ignoring the top node, material driven setting.
I know that SW uses the face, body, feature, part, material priority order, but literally nothing was setup here. And still somehow the features get their appearance entry upon creation.
I could just delete the feature appearance from the appearance tab, but making a new feature, create a new feature entry in the appearance tab, same with RMB and delete all visual state appearance (or whatever is called in the english version, sorry if the name is inaccurate) .
how could I reset a PRTDOT appeareance to stick by default to the material color only?
I tried some vba snippets as well, but probably I am just missing the property messing with the appearance creation order…
thank you In advance.
