So I have a grid pattern of holes. One direction is numbers 1,2,3 and so on depending on number of holes. The other direction is A, B, C etc depending on number of holes.
Is there a way to connect the array to the lettering in such a way that if the array pattern is changed that the numbering also updates? For instance if I have the array at 1,2,3 and A,B,C 3X3 and then change it to 4X4 the lettering will change to 1,2,3,4 and A, B, C, D? The lettering is in a sketch.
