No subscription services
I probably would not go to SW2024 SP4. There was an issue with sketches not staying absorbed when using Hole Wizard. Then when you upgraded to SP5 I believe the only way to fix the issue was to delete the hole wizard feature from the part & recreate it.
https://forum.cadmunity.com/t/fyi-2024-sp04-is-now-available-for-download/3254/1
Edited to correct above link.
