I’m writing a macro that iterates through a drawing and changes the style of BOM Balloons, but It errors with “Object or variable With block variable not set.”
Here’s the relevent code:
For j = 0 To UBound(swAnnotations)
If DecodeAnnotType(swAnnot.GetType) = "swNote" Then
Set swAnnot = swAnnotations(j)
Set swNote = swAnnot.GetSpecificAnnotation()
Debug.Print "Name: " & swAnnot.GetName()
Debug.Print " Type: " & swAnnot.GetType
Debug.Print " Style: " & swNote.GetBalloonStyle
Set swNote = swModelDocExt.EditBalloonProperties2(swBS_SplitCirc, swBF_5Chars, swBalloonTextCustom, "Upper", swBalloonTextCustom, "Lower", 0, True, 1, "X", 0.0355)
Next j
and here’s the immediate window output:
Type: 6
Style: 1
Type: 6
The style is not shown because of it erroring out.
I tried the example code from https://help.solidworks.com/2022/english/api/sldworksapi/edit_balloon_example_vb.htm where it operates on a note (balloon) that is selected by the user and it works fine. It’s as if my EditBalloonProperties2 is corrupting the balloon that was selected using GetSpecificAnnotation(). My “Set swNote” statement is copied verbatim from the SW API Help example.
Thanks for your help.
