Seeing direct edits splattered in the feature tree that edit something that could have been done in the sketch really curdles my blood, people that do that need to just use SE SyncTech and never keep a sketch.
There are occasions where the rotate or offset face (not so much move) are a valid method of generating the solid that would otherwise be more complicated without them. Sometimes the process is more obvious to the next person to use the model using a simple extrude of a triangle or parallelogram then rotate a couple of the faces to generate the compound angles. Yeah, it could be done with multiple sketches on ref planes connected with a loft and maybe another projected cut from another angled ref plane. In the end the simple extrude and rotate face seems to be more robust for future edits and my favorite is it will leave me with planar faces to work.
I will sometimes use offset faces when doing Boolean operations.
In this usage I want to see the feature in the tree as it’s not some hidden fix of a lazy person, it’s a real step in the process of generating the solid.
Disclaimer, I haven’t used this much in Solidworks yet, much more in Solid Edge.
Lastly, if move/rotate/offset face(s) still fries your nerves don’t forget about replace face.
