Material Mass Macro
Would anyone happen to have a macro that can traverse through the top level assembly, and get the mass of specific material types?
I would like to look for specifically .. these materials types, ignore any hidden or suppressed.
“Aluminum - 6061”
“Aluminum Hex - 6061”
“Aluminum Angle - 6061”
“Aluminum - Tooling Plate”
“Aluminum Hex - Extrusion”
and have a popup that will display the total weight in KG
and if possible in that same popup, a separate line item that would display the weight in KG for “Welded - Aluminum”
Any help would be very greatly appreciated !!
Thanks,
Mark
The mass of specific material types are set in the material data base.
If I am wondering if I have the material set right for a part in the assembly I tend to go to the assembly visualization tab to see if any parts look off. Then check the material.
[Pedantic]
The density is set in the material database. The mass is a factor of the density and volume.
[/Pedantic]
Not really sure what you guys are talking about?
I have all the materials already set for each part. There are many parts in many assemblies all with different materials, and they are all in 1 main assembly.
I am trying to see if there is a macro available that could traverse through all of the files in the top level assembly, give the the total mass of certain materials only, not the entire mass of the whole assembly.
So a mass of just the Aluminum details … or just all the brass details … etc.
Does that make sense?
Thanks,
Mark
Hi Bradford,
Have you considered using a parts only BOM and export it to excel to do the sum there? Or is this not something you want to do?
Excel has the advantage over SolidWorks BOM’s it can update values using formula’s.
Eddy
Just trying to avoid extra steps that could result in operator error.
A popup with the Mass of those particular materials would be ideal.
Saves the extra steps, and prevents a designer from math errors.
If I would do this manualy then I would also use ‘Assembly Visualization’ and doing the following steps;
  1. add the material column, if missing.
  2. sort this column and select the part with equal material.
  3. Go back to the FeatureManager Design Tree
  4. Go to Isolate mode. S key or right click empty space.
    Make sure hide is selected.
  5. Open Mass Properties and make sure ‘Include hidden bodies/components’ is deselect.
I was thinking of using the display states for the materials. Since it seems that we are looking for the total weight of specific materials in the assembly. The Assembly Visualization is a great tool when things like this are needed to be done.
I did try the Assembly visualization (works great for a manual work around !) Thank you!
This is what I am trying to do by macro.
  1. Accurately sums the mass of specific materials,
  2. Skips suppressed and hidden components,
  3. Displays a pop-up with the result.
This is what I have so far … although I am getting an error.
I am receiving and error. “Object doesn’t support this property or method”
Const swComponentHidden = 0
Const swThisConfiguration = 1
Dim totalMass As Double
Dim targetMaterials As Variant
On Error GoTo ErrorHandler
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then
    MsgBox "No active document. Please open an assembly file.", vbExclamation, "Missing File"
    Exit Sub
If swModel.GetType <> swDocASSEMBLY Then
    MsgBox "This macro only works on assembly documents.", vbExclamation, "Incorrect File Type"
    Exit Sub
Set swAssy = swModel
' Define your specific material list here
targetMaterials = Array( _
    "Aluminum - 6061", _
    "Aluminum Hex - 6061", _
    "Aluminum Angle - 6061", _
    "Aluminum - Tooling Plate", _
    "Aluminum Hex - Extrusion" _
totalMass = 0
Call AccumulateMass(swAssy.GetRootComponent)
MsgBox "✅ Total mass of specified materials: " & Format(totalMass, "0.000") & " kg", vbInformation, "Mass Summary"
Exit Sub
ErrorHandler:
MsgBox "Error encountered: " & Err.Description, vbCritical, “Macro Error”
Sub AccumulateMass(comp As SldWorks.Component2)
Dim visibility As Long
Dim model As SldWorks.ModelDoc2
Dim matName As String
Dim massProps As SldWorks.MassProperty
Dim children As Variant
Dim i As Integer, k As Integer
If comp.IsSuppressed Then Exit Sub
visibility = comp.GetVisibility(swThisConfiguration)
If visibility = swComponentHidden Then Exit Sub
Set model = comp.GetModelDoc2
If Not model Is Nothing Then
    matName = model.GetMaterialPropertyName2("", "")
    For k = LBound(targetMaterials) To UBound(targetMaterials)
        If StrComp(matName, targetMaterials(k), vbTextCompare) = 0 Then
            Set massProps = model.Extension.CreateMassProperty
            totalMass = totalMass + massProps.Mass
            Exit For
    Next k
children = comp.GetChildren
If Not IsEmpty(children) Then
    For i = 0 To UBound(children)
        Call AccumulateMass(children(i))
    Next i
Do you need to account for different materials applied to different configurations of the same part?
Here is a full working macro for this project in case anyone would like to use it or modify it.
Option Explicit
Dim materialList As Variant
Dim massByMaterial As Object
Sub Main()
    Dim swModel As ModelDoc2
    Dim swConf As Configuration
    Dim rootComp As Component2
    If swModel Is Nothing Or swModel.GetType <> swDocASSEMBLY Then
        MsgBox "Please open an assembly document.", vbExclamation
        Exit Sub
    Set swConf = swModel.GetActiveConfiguration
    Set rootComp = swConf.GetRootComponent3(True)
    If rootComp Is Nothing Then
        MsgBox "Root component not found. Ensure the assembly is fully loaded.", vbCritical
        Exit Sub
    materialList = Array( _
        "pfgmaterials|aluminum - 6061", _
        "pfgmaterials|aluminum hex - 6061", _
        "pfgmaterials|aluminum angle - 6061", _
        "pfgmaterials|aluminum - tooling plate", _
        "pfgmaterials|aluminum - extrusion", _
        "pfgmaterials|welded aluminum base" _
    totalMass = 0
    Set massByMaterial = CreateObject("Scripting.Dictionary")
    TraverseComponents rootComp
    ShowMassSummary
Sub TraverseComponents(startComp As Component2)
    Dim queue As Collection
    Dim current As Component2
    Dim child As Component2
    Dim i As Long
    Set queue = New Collection
    queue.Add startComp
    Do While queue.Count > 0
        Set current = queue(1)
        queue.Remove 1
        If Not current.IsSuppressed And current.Visible = swComponentVisible Then
            ProcessComponent current
            children = current.GetChildren
            If IsArray(children) Then
                For i = LBound(children) To UBound(children)
                    Set child = children(i)
                    If Not child Is Nothing Then queue.Add child
                Next i
    Loop
Sub ProcessComponent(comp As Component2)
    Dim model As ModelDoc2
    Dim massProps As Variant
    Dim massKg As Double
    If model Is Nothing Then Exit Sub
    matName = Trim(LCase(model.MaterialIdName))
    If Not IsInMaterialList(matName) Then Exit Sub
    massProps = model.GetMassProperties
    If IsEmpty(massProps) Then Exit Sub
    massKg = massProps(5)
    If massKg <= 0 Then Exit Sub
    If massByMaterial.Exists(matName) Then
        massByMaterial(matName) = massByMaterial(matName) + massKg
    Else
        massByMaterial.Add matName, massKg
    If matName <> "pfgmaterials|welded aluminum base" Then
        totalMass = totalMass + massKg
Function IsInMaterialList(matKey As String) As Boolean
    Dim i As Long
    For i = LBound(materialList) To UBound(materialList)
        If matKey = materialList(i) Then
            IsInMaterialList = True
            Exit Function
    Next i
    IsInMaterialList = False
End Function
Sub ShowMassSummary()
    Dim key As Variant
    Dim summary As String
    Dim weldKey As String
    Dim weldMass As Double
    If massByMaterial Is Nothing Then
        MsgBox "Mass dictionary not initialized.", vbCritical
        Exit Sub
    weldKey = "pfgmaterials|welded aluminum base"
    summary = "Mass Summary by Material (kg):" & vbCrLf & vbCrLf
    For Each key In massByMaterial.Keys
        If key <> weldKey Then
            summary = summary & key & ": " & Format(massByMaterial(key), "0.00") & " kg" & vbCrLf
    Next key
    summary = summary & vbCrLf & "-----------------------------" & vbCrLf
    summary = summary & "Total Combined Mass (excluding Welded Base): " & Format(totalMass, "0.00") & " kg" & vbCrLf
    If massByMaterial.Exists(weldKey) Then
        weldMass = massByMaterial(weldKey)
        summary = summary & "Welded Aluminum Base: " & Format(weldMass, "0.00") & " kg"
    MsgBox summary, vbInformation, "Material Mass Summary"
Thanks for all of your suggestions.
I really appreciate it.
Mark
Two things:
First: I edited your post to correct the formatting of the code. In the future, when posting code, use three backticks on a line before the code and the line after the code so it will auto format and syntax highlight it. Also helpful to put the language at the end of the first three backticks to let the highlighter know. So, like this:
```vba
<your code here>
Second: You are using an obsolete function (ModelDoc::GetMassProperties). It has been marked as obsolete as far back as SW2010. While it may continue to work in future SW versions, it also may not.
Thanks for doing that and for the Suggestion Jim!
