As of SW2025 SP3, Centerline linestyle will be “Solid” unless you set the option to put them on their own layer or manually change them after inserting them.
See Why Are My Centerlines Solid in SOLIDWORKS?
I made a macro that will go through every CenterLine (and CenterMark) in a drawing and set their linestyle to “Center”
Function ChangeCenterlinesToCenterStyle() As Boolean 'Mark Soldan 12/2025
’ Workaround for the SW2025 SP3 CenterMark linestyle regression
’ Forces all CenterLines and CenterMarks to use the “Center” linestyle in all views on all sheets.
Dim ThisProc As String: ThisProc = “ChangeCenterlinesToCenterStyle()”
Dim swDrawing As SldWorks.DrawingDoc
Dim swSheet As SldWorks.Sheet
Dim vSheetNames As Variant
Dim ActiveSheetName As String
Dim sSheetName As String
Dim nAnnotType As Long
Dim vViews As Variant
Dim swView As SldWorks.View
Dim vAnnotations As Variant
Dim swAnnotation As SldWorks.Annotation
Dim swCenterMark As SldWorks.CenterMark
Dim i As Long
Dim j As Long
Dim k As Long
Dim BoolStatus As BooleanDebug.Print "== BEGIN " & ThisMacro & " / " & ThisProc ChangeCenterlinesToCenterStyle = False Set swApp = Application.SldWorks Set swModel = swApp.ActiveDoc If swModel Is Nothing Then Debug.Print "No active document. Please open a drawing." ChangeCenterlinesToCenterStyle = False Exit Function End If If swModel.GetType <> swDocDrawing Then Debug.Print "Active document is not a drawing." ChangeCenterlinesToCenterStyle = False Exit Function End If Set swDrawing = swModel vSheetNames = swDrawing.GetSheetNames If IsEmpty(vSheetNames) Then Debug.Print "No sheets found in the drawing." ChangeCenterlinesToCenterStyle = True Exit Function End If Set swSheet = swDrawing.GetCurrentSheet ActiveSheetName = swSheet.GetName For i = LBound(vSheetNames) To UBound(vSheetNames) sSheetName = vSheetNames(i) Set swSheet = swDrawing.Sheet(sSheetName) If Not swSheet Is Nothing Then vViews = swSheet.GetViews If Not IsEmpty(vViews) Then For j = LBound(vViews) To UBound(vViews) Set swView = vViews(j) If Not swView Is Nothing Then vAnnotations = swView.GetAnnotations If Not IsEmpty(vAnnotations) Then For k = LBound(vAnnotations) To UBound(vAnnotations) Set swAnnotation = vAnnotations(k) nAnnotType = swAnnotation.GetType If nAnnotType = 15 Then 'This is a CenterLine swModel.ClearSelection2 True BoolStatus = swAnnotation.Select3(False, Nothing) If BoolStatus Then swModel.SetLineStyle "CENTER" End If ElseIf nAnnotType = 13 Then 'This is a CenterMark Set swCenterMark = swAnnotation.GetSpecificAnnotation If Not swCenterMark Is Nothing Then swCenterMark.CenterLineFont = True End If End If Next k End If End If Next j End If End If Next i swModel.ActivateSheet ActiveSheetName swModel.ClearSelection2 True swModel.ForceRebuild3 False swModel.GraphicsRedraw2 ChangeCenterlinesToCenterStyle = True Debug.Print "== DONE " & ThisMacro & " / " & ThisProcEnd Function
