The code that follows fulfills your request. The only issue I can identify is that the Origin Axes don’t align as they would if I did it manually.
Dim swAsm As SldWorks.AssemblyDoc
Dim swSelComp As SldWorks.Component2
Dim swSelComp1 As SldWorks.Component2
Dim swSelComp2 As SldWorks.Component2
Dim swSketch As SldWorks.Sketch
Dim swSkPoint As SldWorks.SketchPoint
Dim swCoincMateData As SldWorks.CoincidentMateFeatureData
Dim EntitiesToMate(1) As Object
Dim EntitiesToMateVar As Variant
Dim i As Integer
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then MsgBox "Please open a Assembly!": End
If swModel.GetType <> swDocASSEMBLY Then MsgBox "Please open a Assembly!": End
Set swAsm = swModel
Set swSelComp1 = swSelMgr.GetSelectedObjectsComponent(1)
Set swSelComp2 = swSelMgr.GetSelectedObjectsComponent(2)
' Check selection
If swSelMgr.GetSelectedObjectCount2(-1) > 2 Then MsgBox "Please select only two components!": End
If swSelMgr.GetSelectedObjectCount2(-1) <> 2 Then MsgBox "Please select two components!": End
If swSelComp1 Is Nothing Or swSelComp2 Is Nothing Then MsgBox "Please select two components!": End
' Get origins to mate
For i = 0 To 1
Set swSelComp = swSelMgr.GetSelectedObjectsComponent(i + 1)
Set swFeat = swSelComp.FirstFeature
If "OriginProfileFeature" = swFeat.GetTypeName Then
Set swSketch = swFeat.GetSpecificFeature2
Set swSkPoint = swSketch.GetSketchPoints2()(0)
Set EntitiesToMate(i) = swSkPoint
Exit Do
Loop
Next i
EntitiesToMateVar = EntitiesToMate
' Create CoincidentMateFeatureData
Set swCoincMateData = swModel.CreateMateData(0)
swCoincMateData.EntitiesToMate = (EntitiesToMateVar)
swCoincMateData.MateAlignment = 0
swModel.CreateMate swCoincMateData
I contacted API Support and they suggest using AddMate5 with swMateCOORDINATE, which will align the axes.
The code snippet below works as expected. Have fun with it
Dim SelComps(1) As Object
Dim i As Integer
Set swAsm = swModel
Set SelComps(0) = swSelMgr.GetSelectedObjectsComponent(1)
Set SelComps(1) = swSelMgr.GetSelectedObjectsComponent(2)
If SelComps(0) Is Nothing Or SelComps(1) Is Nothing Then MsgBox "Please select two components!": End
swModel.ClearSelection2 True
For i = 0 To 1
Set swFeat = SelComps(i).FirstFeature
swSkPoint.Select4 True, Nothing
Exit Do
Loop
Next i
swAsm.AddMate5 20, -1, False, 0, 0, 0, 0, 0, 0, 0, 0, False, False, 0, Empty
swModel.EditRebuild3
I was trying addmate5 for a while and the answer helped me to understand the problem was the axis alignment required an undocumented “-1” after the swMateCOORDINATE “20”. lol
Member Description
swAlignAGAINST Obsolete. Do not use.
swAlignNONE Obsolete. Do not use.
swAlignSAME Obsolete. Do not use.
swMateAlignALIGNED 0
swMateAlignANTI_ALIGNED 1
swMateAlignCLOSEST 2
Has anyone ever reported this missing enum to solidworks? I don’t know the details, but reporting things like these really helps. There is a feedback button on every documentation page. They only fix it in the latest SW version, but still.
I am not a VBA specialist, but I’m very enthusiastic about automation. I’ve been using AI to build automation tools for my company, mainly for an assembly builder workflow based on the production BOM.
The scope of my task is to mate parts automatically using Coordinate Systems. I came across a script with the help of AI that gathers the part insertion list from Excel, inserts the parts priority-wise, and maps the parent/child Coordinate Systems successfully.
Currently, the script works using AddMate5 with swMateCOINCIDENT. However, I’m facing one issue — I’m unable to enable the “Align Axes” option through the script. Because of that, the coordinate systems mate coincidently, but their axes orientation does not align correctly.
I noticed that using AddMate5 with swMateCOORDINATE seems to solve this for origins. So I wanted to ask:
Is there already a macro/API approach available to mate Coordinate Systems directly with aligned axes enabled automatically?
Any guidance or example would be really helpful. Thanks!
