Macro to create layer and set it to active state
Hye,
I’m expected to create a Macro that could create a Layer, and set it in an active state, before adding a BOM in this layer, in my assembly drawing.
I’ve search on site like, Codestacks or cadCoder, but nothing that i can really use to do this.
A have allready find a macro to add a BOM, i just nead the part with Layer.
If someone could help me.
Thanks a lot.
Do either of these links help?
https://help.solidworks.com/2023/english/api/sldworksapi/solidworks.interop.sldworks~solidworks.interop.sldworks.idrawingdoc~createlayer.html?verRedirect=1
https://help.solidworks.com/2023/English/api/sldworksapi/SolidWorks.Interop.sldworks~SolidWorks.Interop.sldworks.ILayerMgr~SetCurrentLayer.html?verRedirect=1
Hye SPerman,
Thanks you for the links.
I’ve allready seen this kind of help on solidworks, but i don’t know how to use it.
Especially for the “Declaration” field. Where i put that in my VBA macro ?
What mean the “_” at the end of each line ?
looking forward to hearing from you
Example macro below:
'==================== Preamble ===================='
Option Explicit
Dim swApp               As SldWorks.SldWorks
Dim swModel             As SldWorks.ModelDoc2
Dim swDraw              As SldWorks.DrawingDoc
Dim boolstatus          As Boolean
Dim lErrors             As Long
Dim lWarnings           As Long
'==================== MainCode ===================='
    'Get active document
    Set swModel = swApp.ActiveDoc
    'Display message and terminate if not drawing
    If Not swModel.GetType() = swDocDRAWING Then
        'If not drawing
        MsgBox "Macro only work on drawing file.", vbCritical, "ERROR"
        End
    Set swDraw = swModel
    'Create Layer
    boolstatus = swDraw.CreateLayer("TestLayer", "TestDescription", 255, swLineCONTINUOUS, swLW_THICK, True)
    'Activate Layer
    boolstatus = swDraw.SetCurrentLayer("TestLayer")
    Set swModel = Nothing
You will need to change the two line below manually:
'Create Layer
boolstatus = swDraw.CreateLayer(“TestLayer”, “TestDescription”, 255, swLineCONTINUOUS, swLW_THICK, True)
'Activate Layer
boolstatus = swDraw.SetCurrentLayer(“TestLayer”)
In VBA, When a line of code is too long, you can divide it to several lines by adding a "_ " at the end of the code.
So if you have a line like :
If swFeat.GetTypeName = "SolidBodyFolder" Or swFeat.GetTypeName = "CutListFolder" Or swFeat.GetTypeName = "SubWeldFolder" Then
You can add an _ to the end and continue in the next line.
Sometimes it makes your code much better readable.
If swFeat.GetTypeName = "SolidBodyFolder" Or _
        swFeat.GetTypeName = "CutListFolder" Or _
Tanks you Tera.
And thank you Zwei, you helped me find a solution.
However, some problems remain:
  • The BOM, which in the VBA program is generated after layer creation, is not created with the active layer, but in another layer “0”.
    The new layer becomes active in SW, but the BOM does not take it into account. Nor is the BOM created with the layer
    defined in Options/Document properties/Tables/BOM.
    You can see the Vba lines below to test it.
What could be the solution ?
Const ANCHOR_TYPE As Integer = swBOMConfigurationAnchorType_e.swBOMConfigurationAnchor_TopRight
Const BOM_TYPE As Integer = swBomType_e.swBomType_PartsOnly
Const TABLE_TEMPLATE_SIMPLE As String = “\vmisw2022\DataSolidWorks\ModelesVMI\Tables\Nomenclatures-Qte-CodeSAP.sldbomtbt”
Const TABLE_TEMPLATE_STD As String = “\vmisw2022\DataSolidWorks\ModelesVMI\Tables\NomenclaturesSAP.sldbomtbt”
'Const TABLE_TEMPLATE_BASE_FR As String = “\vmisw2022\DataSolidWorks\ModelesVMI\Tables\NomenclaturesSAP_SIMP_FR.sldbomtbt”
'Const TABLE_TEMPLATE_BASE_EN As String = “\vmisw2022\DataSolidWorks\ModelesVMI\Tables\NomenclaturesSAP_SIMP_EN.sldbomtbt”
'Const TABLE_TEMPLATE_BASE_AL As String = “\vmisw2022\DataSolidWorks\ModelesVMI\Tables\NomenclaturesSAP_SIMP_AL.sldbomtbt”
'Const TABLE_TEMPLATE_BASE_ES As String = “\vmisw2022\DataSolidWorks\ModelesVMI\Tables\NomenclaturesSAP_SIMP_ES.sldbomtbt”
Const INDENTED_NUMBERING_TYPE As Integer = swNumberingType_e.swNumberingType_Flat
Const DETAILED_CUT_LIST As Boolean = False
Const FOLLOW_ASSEMBLY_ORDER As Boolean = True
Const ALL_SHEETS As Boolean = False
Dim lErrors As Long
Option Explicit
Set swDraw = swApp.ActiveDoc
Dim lErrors As Long
'If not drawing
MsgBox “Macro only work on drawing file.”, vbCritical, “ERROR”
End
'Création calque BOM_SIMPLE
boolstatus = swDraw.CreateLayer(“BOM_SIMPLE”, “Nomenclature Ss Description”, 255, swLineCONTINUOUS, swLW_THICK, True)
'Active calque BOM_SIMPLE
boolstatus = swDraw.SetCurrentLayer(“BOM_SIMPLE”)
'If ALL_SHEETS Then
'Dim vSheetNames As Variant
'vSheetNames = swDraw.GetSheetNames
'Dim activeSheetName As String
’ activeSheetName = swDraw.GetCurrentSheet().GetName
'Dim i As Integer
'For i = 0 To UBound(vSheetNames)
'Dim swSheet As SldWorks.sheet
’ Set swSheet = swDraw.sheet(CStr(vSheetNames(i)))
'InsertBomTable swDraw, swSheet
'Next
'swDraw.ActivateSheet activeSheetName
'Else
InsertBomTable swDraw, swDraw.GetCurrentSheet
'End If
Sub InsertBomTable(draw As SldWorks.DrawingDoc, sheet As SldWorks.sheet)
If False = draw.ActivateSheet(sheet.GetName()) Then
Err.Raise vbError, “”, "Failed to activate sheet " & sheet.GetName
Dim vViews As Variant
vViews = sheet.GetViews
Dim swView As SldWorks.View
Set swView = vViews(0)
Dim swBomTableAnn As SldWorks.BomTableAnnotation
Set swBomTableAnn = swView.InsertBomTable4(True, 0, 0, ANCHOR_TYPE, BOM_TYPE, “”, TABLE_TEMPLATE_SIMPLE, False, INDENTED_NUMBERING_TYPE, DETAILED_CUT_LIST)
If Not swBomTableAnn Is Nothing Then
swBomTableAnn.BomFeature.FollowAssemblyOrder2 = FOLLOW_ASSEMBLY_ORDER
Else
Err.Raise vbError, “”, "Failed to insert BOM table into " & swView.Name
  • Is it possible, once the BOM has been created with the new layer, to hide this layer?
Thanks you so much. :smiley:
InsertBOM does not set the layer, you will need to set the layer after you insert the code
Set swTable = swBomTableAnn
swTable.GetAnnotation.Layer = "BOM_SIMPLE"
Thanks you so much. > :smiley:
If you mean turning off the layer visibility, then yes. You can even do it before inserting the bom if you want…
'Turn layer visibility off
    Set swLayerMgr = swModel.GetLayerManager
    Set swLayer = swLayerMgr.GetLayer("BOM_SIMPLE")
    swLayer.Visible = False
I had updated your code as shown below:
Option Explicit
Dim swTable As SldWorks.TableAnnotation
Dim swLayerMgr As SldWorks.LayerMgr
Dim swLayer As SldWorks.Layer
Dim lErrors As Long
'If not drawing
End
'If ALL_SHEETS Then
'Dim i As Integer
'Next
'Else
'End If
'Set BOM Layer
swTable.GetAnnotation.Layer = “BOM_SIMPLE”
'Set turn off layer visibility
Set swLayer = swLayerMgr.GetLayer(“BOM_SIMPLE”)
Else
Hello Zwei,
It seems that the modifications you made generate a compilation error when I run the macro.
And since I’m not a VBA specialist at all, I can’t find the solution to this error.
Could you please test it at home to see if you get the same thing?
Thanks a lot!
The problem (for me at least) occurs here:
swBomTableAnn is defined in the subroutine, but not in the main function.
Sperman is correct, i missed out the sub routine, move the code that set the table layer to the subroutine should fix the issue
Option Explicit
Dim lErrors As Long
'If not drawing
End
'If ALL_SHEETS Then
'Dim i As Integer
'Next
'Else
'End If
'Set BOM Layer
Else
Hello Zwei and Superman
Thanks for your help, it works very well.
UU
