Macro: Process Drawing
This macro creates a PDF of any sheets that don’t have “DXF” in the name. It then produces a DXF of a sheet with “DXF” in the name. (If you have multiple DXF sheets, it will overwrite all but the last. My drawings only have 1 DXF sheet.)
There is a bunch of file name manipulation that won’t make sense to anyone else, but I’ll leave that for you to sort out. There are likely some declared variables that are unused. This has evolved over a number of years.
As always, credit goes to a number of un-named internet sources and published macros that I borrowed from. I am an engineer who can bash his way through generating code that works, but only if I have good examples to start from.
The one known issue I haven’t dealt with is that the number of sheets in the title block count’s the DXF, even though it isn’t present in the pdf.
Option Explicit
Dim Part As Object
Dim longstatus      As Long
Dim swApp           As SldWorks.SldWorks
Dim swModel         As SldWorks.ModelDoc2
Dim swDraw          As SldWorks.DrawingDoc
Dim swView          As SldWorks.View
Dim swModelDocExt   As SldWorks.ModelDocExtension
Dim swCustPropMgr   As CustomPropertyManager
Dim sModelName      As String
Dim sModelPath      As String
Dim sNewPath        As String
Dim sNewName        As String
Dim sModelFullName  As String
Dim sDxfFullName    As String
Dim CropPos         As Integer
Dim sRev            As String
Dim sDesc           As String
Dim Bool            As Boolean
Dim Junk            As String
Dim ModelType       As Object
Dim LocalPath       As String
Dim strSheetName()  As String
Dim swExportPDFData As SldWorks.ExportPdfData
Dim varSheetName    As Variant
Dim lErrors         As Long
Dim lWarnings       As Long
Dim s               As Variant
Private Declare PtrSafe Sub SHAddToRecentDocs Lib "shell32" _
(ByVal uFlags As Long, ByVal pv As Any)
Sub ProcessDwg()
Set ModelType = swApp.ActiveDoc
If ModelType Is Nothing Then ' Check to see if a document is loaded
    ' If no model is currently loaded, then exit
    Exit Sub
If (ModelType.GetType <> 3) Then  'CHeck to see if document is a drawing. prt=1, asm=2, drw=3
    MsgBox ("Not a Drawing File")
    Exit Sub
Set swDraw = swApp.ActiveDoc
longstatus = swDraw.Save3(1, lErrors, lWarnings)
Set swView = swDraw.GetFirstView 'this gets the sheet
Set swView = swView.GetNextView 'this gets the first view
Set swModel = swApp.ActiveDoc
Set swExportPDFData = swApp.GetExportFileData(1)
Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
Bool = swCustPropMgr.Get4("Revision", False, sRev, Junk)
Bool = swCustPropMgr.Get4("Long Name", False, sDesc, Junk)
'this is the full name and path
sModelPath = swModel.GetPathName
'get filename from full path
CropPos = InStrRev(sModelPath, "\")
sNewName = Right(sModelPath, (Len(sModelPath) - CropPos))
'strip slddrw extension
sNewName = Left(sNewName, Len(sNewName) - 7)
'add revision and description
'Set swCustProp = swModelDocExt.CustomPropertyManager("")
sNewName = sNewName + "-" + sRev + "-" + sDesc
sNewName = Replace(sNewName, ",", "")
sNewName = Replace(sNewName, ".", "_")
sNewName = Replace(sNewName, "/", "_")
sNewName = Replace(sNewName, "\", "_")
sNewName = Replace(sNewName, """", "")
'add pdf extension
sNewName = sNewName + ".pdf"
'get path
sNewPath = Left(sModelPath, CropPos - 1)
'remove subdirectory from path
CropPos = InStrRev(sNewPath, "\")
sNewPath = Left(sNewPath, CropPos)
'add drawings folder
sNewPath = sNewPath + "drawings\"
sModelFullName = sNewPath + sNewName
' Save As
'save to Onedrive
LocalPath = Mid(sModelFullName, 21)
sModelFullName = "C:\Users\DSPerman\CTW Automation\CAD - General" + LocalPath
sDxfFullName = Left(sModelFullName, (Len(sModelFullName) - 3)) + "dxf"
'get list of sheets, excluding dxf
ReDim strSheetName(0)
    For Each s In swDraw.GetSheetNames
        longstatus = swDraw.ActivateSheet(s)
        swApp.ActiveDoc.Extension.ViewZoomToSheet
        If Not UCase(s) Like "*DXF*" Then
            strSheetName(UBound(strSheetName)) = s
            ReDim Preserve strSheetName(UBound(strSheetName) + 1)
    Next s
    varSheetName = strSheetName
' Save As
    If swExportPDFData Is Nothing Then MsgBox "Nothing"
    longstatus = swExportPDFData.SetSheets(swExportData_ExportSpecifiedSheets, varSheetName)
    longstatus = swModelDocExt.SaveAs(sModelFullName, 0, 0, swExportPDFData, lErrors, lWarnings)
SHAddToRecentDocs 2, sModelFullName
'process dxf
        If UCase(s) Like "*DXF*" Then
            longstatus = swDraw.SaveAs3(sDxfFullName, 0, 2)
    Next s
longstatus = swDraw.ActivateSheet(strSheetName(0))
You may want to add codes to export active sheet only when saving as DXF, otherwise if the users have a different setting for the DWG/DXF export, they may end up with many unwanted DXF files or sheets.
Now all you need is some code to actually attach that DXF to the PDF so that you don’t have to manage two separate files… (yes, you can attach any type of file inside a PDF!) You can do that by using VBA to execute a command line to PDFtk.
