I am looking for help to display part of a file name that is after a certain number of characters or a dash symbol.
For example, I have a part with file name 1-123456-001
I want to be able to display only the 001 from the end after the second dash on a drawing. How can this be trimmed and displayed?
Here is another version, it can be simplified but I prefer it.
Option Explicit
Dim FileName As String
Set swModel = swApp.ActiveDoc
FileName = swModel.GetPathName
FileName = Mid(FileName, InStrRev(FileName, "\") + 1)
FileName = Left(FileName, InStrRev(FileName, ".") - 1)
FileName = Mid(FileName, InStrRev(FileName, "-") + 1)
Debug.Print FileName
I should add that ideally I could run the macro and have it plug into a custom property value (ex PRP: “End of filename”) so I could run this across hundreds of drawings.
Deepak, based on this post and your help from the past I was able to cobble something together that works on Solidworks Parts, but I would like it to work on the drawing files as well.
Also, it would be a bonus for this macro to automatically run when saving the document.
Option Explicit
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim bRet As Boolean
Dim PropValue As String
Set swCustPropMgr = swModel.Extension.CustomPropertyManager("Default")
If Not swModel Is Nothing And swModel.GetPathName <> "" Then
PropValue = Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1)
PropValue = Left(PropValue, InStrRev(PropValue, ".") - 1)
PropValue = Mid(PropValue, InStrRev(PropValue, "-") + 1)
bRet = swCustPropMgr.Add3("DETAIL #", 30, PropValue, 1)
swModel.Save
Set swCustPropMgr = swModel.Extension.CustomPropertyManager(“Default”)
with
If swModel.GetType = 3 Then
Set swCustPropMgr = swModel.Extension.CustomPropertyManager(“”)
Else
Deepak,
Rather than plugging this into another property within the drawing/part, would it be possible to create a property that is linked to the filename but always displays the number after the dash? This way it is always up-to-date regardless of if the filename has changed.
This can only be done via a macro or add-in, which will update the property value on file save. You can use design table as well, and derive the property via excel formulas.
