My 1st post here! looking for a macro which I think might be helpful for all actually.
So you know how you can use tab and shift-tab to hide & unhide hovered components; love that feature, super convenient, right?
Can something like that be done but for transparency (basically a toggle)? Hover would be best, but I assume it won’t be as easy? How about pre-selecting the component, press a key (assigned to the said macro), make the part transparent, click again and make it opaque? I searched for such a macro a bit, no luck.
I’m using 2020 and transparency toggle or anything like that won’t shop up in the commands (under keyboard tab in customize menu) when you search for it.
Yeah I am aware of that, but I’m trying to avoid the extra clicks. I like to be able to assign a key to it and toggle quickly between opaque and transparent, solidworks currently doesn’t allow that, hence my inquiry about a macro that can do that.
Thanks for the link…for a second I thought I’m missing something after josh comment, but yeah definitely you can’t assign a hotkey to this command without a macro.
As for the api link, unfortunately I am not knowledgeable enough to write the macro
