I’ve been looking for a macro to rename all sketches in feature tree to the name of the feature it belongs to + Sketch.
Something like :
Does anyone know a macro that does something like this?
thanks.
There is a macro to hide all sketches in a model but I have not seen a one to rename them based on their feature name. This one will have to be made.
How would it work when sketches are shared?
We never use shared Sketches.
But for the sake of changes in our workflow in future, I prefer it be named with the first feature that use that sketch.
If it makes any problem, renaming it to the last feature is OK as well.
thanks.
Now that it seems what I need is not possible,
is it possible to rename only the selected sketch to → the name of the feature it belongs to + SK?
thanks again.
Here is a quick (dirty) macro that does the job.
Sub Mian()
Dim swSubFeature As SldWorks.Feature
Dim FeatureName As String
Dim i As Integer
Set swPart = swApp.ActiveDoc
Set swFeat = swPart.FirstFeature
While Not swFeat Is Nothing
If swFeat.GetTypeName2 <> "ProfileFeature" Then
Set swSubFeature = swFeat.GetFirstSubFeature
While Not swSubFeature Is Nothing
If swSubFeature.GetTypeName2 = "ProfileFeature" Then
FeatureName = swFeat.Name & " Sketch"
While False <> swPart.FeatureManager.IsNameUsed(swNameType_e.swFeatureName, FeatureName)
i = i + 1
FeatureName = swFeat.Name & " Sketch" & (i)
Wend
swSubFeature.Name = FeatureName
Set swSubFeature = swSubFeature.GetNextSubFeature
Wend
Wend
Deepak still beeing the man ![]()
Thanks to both.
Will give it a try.
gupta9665 Million thanks.
Works perfect.
I only had to add a If Left(swSubFeature.Name, 6) = “Sketch” Then to prevent renaming the sketches that have already been renamed manually, and add a i = 0 after GetNextFeature to reset the counter for each feature.
I really don’t know how to appreciate this favor.
Thanks again.
