Load Next Configuration Macro
Hi All,
We have can thousands of configurations within part and assembly and I am trying to automate the tedium of uploading each one to our our ERP software. We have been provided an addin which provides an upload button for the currently active configuration. My thought was to use Microsoft Power Automate which can record and playback keystrokes and mouse movements to load a configuration and press the upload button.
From what I can tell there is no keyboard button which can select and activate the next configuration. Recording a mouse action is not practical since the next configuration is always in a different position.
I have zero experience writing code, but would be very grateful for anyone to point me to an example I could use as a starting point to create a “load next configuration” macro which I can then customize into a button on the interface. Bonus if I could figure out how to put up an error message if the macro is run at the last configuration.
Jonas,
The ‘next’ configuration here, is very subjective. Could you dwelve a bit more into detail? What represents the ‘next’ configuration? Are you speaking of the next configuration in an alphabetical order, or a next configuration in a creation order, or something else?
To execute what you speak of, I create a temporary assembly where I can have a pattern that represents the number of occurances and then “configure” the configurable component.
Then I send the info to our ERP using our macro that creates a BOM to copy and paste it to our ERP.
Our parts and assemblies configurations are created with design tables. In the configuration tree these can be shown in the order created, alphabetical, or by the order they are listed in the design table. For my use it does not matter they way they are organized or even if it is the “next” one down the line so long as the macro cycles through all of them once.
We have the piece that extracts the BOM to our ERP already. But it only does it for the active configuration. I just need a button to load the “next” configuration.
Hi Jonas
I have no idea what Microsoft Power Automate can do exactly, but I assume that it can wait for windows and press buttons inside them. After starting the SW macro, the configurations are read from the model, and each click on yes loads the next one. While the window is open on top, actions can be done in the CAD.
Option Explicit
    Dim swConfigs As Variant
    Dim i As Integer
    Set swModel = swApp.ActiveDoc
    swConfigs = swModel.GetConfigurationNames
    For i = 0 To UBound(swConfigs)
        If Not NextConfig Then Exit Sub
        swModel.ShowConfiguration2 swConfigs(i)
    Next i
    Set swModel = Nothing
    Set swApp = Nothing
Function NextConfig() As Boolean
    Dim wShell As Object
    Set wShell = CreateObject("WScript.Shell")
    ' https://docs.microsoft.com/en-us/previous-versions//x83z1d9f(v=vs.85)?redirectedfrom=MSDN
    If wShell.Popup("Next config?", 60, "Switch configs", 4 + 32 + 4096) = 6 Then NextConfig = True
    Set wShell = Nothing
End Function
BiI ERP-PDM
