Inspection Dimension
Is there a way that I can use a hotkey when dimensioning that would add the inspection dimension circle to the next dimension next feature I dimension?
for example … I use ordinate dimensions … i have say 12 items to dimension, 3 of which are critical, so i would want them to be circled. currently, I dimension all of the the dimensions and then go back .. highlight the 3 that i want to mark as inspection dimension, and then click that button to add the circle.
Wondering if i can do that on the fly. Start adding the 12 ordinates, but as I come to the critical dimension, hit ctrl, or alt, or some hotkey so that the next item selected would have the circle added. this could save me some time if its possible.
Thanks,
Mark
Not built in. But if you map this macro to a hotkey, you can hit that button after you insert a dimension and it will add the inspection circle.
It’s actually a bit more versatile than that. It will add the circle to any and all dimensions that are selected at any time. Dimensions are automatically selected immediately after insertion, so that’s why this works. But it will work with your old workflow as well.
    Dim swDim As SldWorks.DisplayDimension
    Dim swSels As SldWorks.SelectionMgr
    Set swSels = swApp.ActiveDoc.SelectionManager
    Dim i As Long
    For i = 1 To swSels.GetSelectedObjectCount2(-1)
        If swSels.GetSelectedObjectType3(i, -1) = swSelDIMENSIONS Then
            Set swDim = swSels.GetSelectedObject6(i, -1)
            swDim.Inspection = True
    Next i
I would add a little logic to toggle the existing value instead of just setting it to True.
    Dim i As Long
            If Not swDim.Inspection = False Then
           Else
    Next i
    mDoc.GraphicsRedraw2
Thank you. Exactly what I was looking for.
Much appreciated.
Mark
Thanks Jim !
Just to clarify, Josh’s code does exactly what you asked for. If you are in the process of adding ordinate dimensions, as soon as you click to place a dimension, you can press your hotkey and it will add the inspection bubble. It may require a little mouse movement for the display to update.
Oh Damn! even better. I see it now. I didn’t realize it at first. Thanks for clarifying!
I don’t think I’d say “exactly”… He did say he wanted the action to apply to the next thing clicked, not the last thing like my code does. :smiley: The next thing would be possible, but significantly more complicated and messy.
I’m very happy with this as it is. This really helps with the workflow and saves time. Thank you very much.
I have an app for this task. It allows you to add dimension #, select specific dimensions, and mark critical dimensions using a triangle symbol - see clip
Dimnum.zip (2.4 MB)
Nice app Christian!
