Inserting a sequence of numbers in a sketch
Hiya,
I do a lot of work with ship layout and one of the basic layout items for all ship systems is a baseline sketch defining the frame spacing.
The layout of the actual spacing is easy enough, but it would be AWESOME if I could generate a sequence of text labels to call out the frame numbers.
As typically there are 150 of these, manually doing this is just a bit tedious. Particularly with the complete lack of text handling capability in sketches.
A quick spelunk around the innerwebs provided nothing.
Is this possible?
thanks
ben
Does this help you? https://www.cadforum.net/viewtopic.php?f=17&t=485&p=13065
Kudos to MJuric.
Wow. That’s brilliant. Yes, thanks!
