I imported many SW (2021) files as sheet metal. Saved them as .psm. However I cannot figure out how to make the part behave as sheet metal. I can create a flat pattern and alter it’s thickness but that does not reflect in the folded model. Short of dimensioning all flanges individually, which would not be acceptable. I don’t see what to do. I came actoss thickness chain in the help but it is not showing up for me. Should I use synchronous or Ordered. Basically all the model were done years ago so the basic geometry is there. I need to refine many of the thicknesses and flange lengths though. I have attached an SW part as I am using the community version.
06h Angle Girder 9c.SLDPRT (151 KB)
Ahh. I found Matts video on importing sheet metal parts. <LINK_TEXT text=“https://www.youtube.com/watch?v=qJRxZYR … attlombard”>https://www.youtube.com/watch?v=qJRxZYR2A4o&ab_channel=mattlombard</LINK_TEXT>
I now j need to know how to alter the thickness.
Material thickness for sheetmetal is one of the mysterious thing that I always wonder why they have kept it so hidden.
Anyway ..
Tools → Variables → Material thickness..
I had tried that before I watched the video but nothing happened. That makes it simple. Do you know how to setup a sheet metal bend table? Or where I look for one I can modify? I have a range of thicknesses in SWG terms 34, 27, 26, 24, 23, 22, 21,and 18. In general I would use R = t.
Now experimenting I noticed something about Synchronous> I tried a big radius and then went back to a small radius. A lot disappeared. I guess this is all part of learning the tool.
As sync is history free modelling workflow like blender, zbrush and others you are forced to either undo or to fix it.
In SE you don’t have bending table based on what sheetmetal thickness you are working with. Are you sure that SW has this ?
Throw something together over the topic ..
https://drive.google.com/file/d/15lXapy43eTa34mwPvG9gRmf2ggMzz9DU/view?usp=share_link
Sorry. I meant Gauge table. Found this in this forum. I’ll check it out tonight. https://www.cadforum.net/viewtopic.php?t=633
[quote=Ronan1961 post_id=28230 time=1682643132 user_id=1405]
[/quote]
Thickness is typically set by changing the Material assigned in the PathFinder node. There is a Gage Properties tab.
That’s great. Really make things quite straight forward. >< Thank you.
