How to unselect "Display sheet Format" in VBA
G’Day
I use a macro to insert a new custom size sheet in a Solidworks 2019 drawing. (I have created a custom template “TAG_MW_Single_View”.) The macro work well and it sets all properties as required. The only thing missing is to deselect “Display sheet format”. I have recorded macro when I do it manually and the code for that is:
Set Part = swApp.ActiveDoc
Part.ClearSelection2 True
boolstatus = Part.SetupSheet5(“MW Sheet”, 12, 12, 1, 20, False, “C:\SWDVault\Engineering\Z00 -
Solidworks\sheetformat\TAG_MW_Single_View.slddrt”, 0.42, 0.297, “Default”, False)
The “Part.ClearSelection2 True” is the code that clears the box, but if I use it in my code it does not work.
I have also tried “swDraw.SheetFormatVisible = False” and that use to work but for some reason it is not working anymore. I must have changed some code somewhere else.
Regards
Jaco
SheetFormatVisible Property
#SPerman - I have tried it before and it use to work, but for some reason it is not working now. This is my code:
Option Explicit
Dim swSheet As Sheet
Dim SelMan As SldWorks.SelectionMgr
Dim retval As Boolean
Dim vSheetProps As Variant
Dim TemplateName As String
Dim instance As ISheet
    TemplateName = "C:\SWDVault\Engineering\Z00 - Solidworks\sheetformat\TAG_MW_Single_View.slddrt"
    Set swDraw = swApp.ActiveDoc
    'swApp.SendMsgToUser "Complete"
    retval = swDraw.NewSheet3("MW Sheet", swDwgPapersUserDefined, swDwgTemplateCustom, 1, 20, False, TemplateName , 0.08, 0.08, "MW View") ' TAG_MW_Single_View.slddrt
    swDraw.ActivateSheet ("MW Sheet")
   ' Get the drawing document
    ' Get the active document
    Set swModel = swApp.ActiveDoc
'    swDraw.SheetFormatVisible = False
    instance.SheetFormatVisible = False
    .......more code
In a similar case, how do I set “Display all configuration of the same part as one item” as “Part configuration Grouping” with VBA code?
Hi RonE
Do you have some wisdom about this issue? It should be very similar to the problem you solved earlier - I am just not skilled enough to connect the dots. grumph
Regards
Jaco
You need to get the current sheet, and then turn off the sheet format visibility.
Try
Option Explicit
Dim swModel As ModelDoc2
Dim currentsheet As Sheet
Dim boolstatus As Boolean
boolstatus = Part.SetupSheet5(“MW Sheet”, 12, 12, 1, 20, False, “C:\SWDVault\Engineering\Z00 - Solidworks\sheetformat\TAG_MW_Single_View.slddrt”, 0.42, 0.297, “Default”, False)
Set currentsheet = swModel.GetCurrentSheet
currentsheet.SheetFormatVisible = False
Thanks gupta9665 . It is now working fine.
