I need to just list all the features in the immediate window, together with the subfeatures and all the dimensions (sketches and feature parameters) which parent is a cutlist body.
I can get the cutlist (body) folder, then the first body, its main features, but no subfeatures, like absorbed sketches and the dimensions.
I can traverse the whole tree ignoring the cutlist folders and get all the dimensions, but I am interested to filter and group those feature for a single body or cutlist, not the whole tree.
' Iterate Through Dimensions in Model Example (VBA)
' This example shows how to iterate through the features and dimensions in a part.
' Preconditions:
' 1. Open public_documents\samples utorial\lesson2 utor1.sldprt.
' 2. Open the Immediate window.
' Postconditions:
' 1. Iterates through the features and dimensions in the part.
' 2. Examine the Immediate window.
' NOTE: Because the part is used elsewhere, do not save changes.
Option Explicit
Dim swSubFeat As SldWorks.Feature
Dim swDispDim As SldWorks.DisplayDimension
Dim swDim As SldWorks.Dimension
Dim swAnn As SldWorks.Annotation
Dim bRet As Boolean
Set swApp = CreateObject("SldWorks.Application")
Set swModel = swApp.ActiveDoc
Set swFeat = swModel.FirstFeature
Debug.Print "File = " & swModel.GetPathName
Debug.Print " " + swFeat.Name
Set swSubFeat = swFeat.GetFirstSubFeature
Do While Not swSubFeat Is Nothing
Debug.Print " " + swSubFeat.Name
Set swDispDim = swSubFeat.GetFirstDisplayDimension
Do While Not swDispDim Is Nothing
Set swAnn = swDispDim.GetAnnotation
Set swDim = swDispDim.GetDimension
Debug.Print " [" & swDim.FullName & "] = " & swDim.GetSystemValue2("") *1000
Set swDispDim = swSubFeat.GetNextDisplayDimension(swDispDim)
Loop
Set swSubFeat = swSubFeat.GetNextSubFeature
Loop
Set swDispDim = swFeat.GetFirstDisplayDimension
Set swDispDim = swFeat.GetNextDisplayDimension(swDispDim)
Loop
Loop
I am dealing with an issue related to different legacy models and the way SW evolved over the time apparently. I leave this comment here as a reminder:
The feature tree has two lists of features: the feature list and the subfeature list.
They are independent from each other and former points at the latter so you must scan the tree like: first feature → first subfeature → all its subfeatures → next feature → all its subfeatures etc
Cutlist folder is a strange beast: there are three kind of tree I saw inside files made in different ways and across ten or more years with SW.
1. some files have the cutlists shown as a feature
2. some files have the cutlists shown as a subfeature
3. some files have the cutlists shown as both features and subfeatures. (same unique id in the tree is duplicated as feature and subfeature)
The reason is apparently, sometimes, the top node “Cutlists” , while visible in the model tree, it is seen as the “ordinary” (at least for parts without the welding feature in the tree) “solid bodies” folder when inquired via API.
If you are filtering the features according to getTypeName be aware of that or the type “cutlistfolder” is going to filter your real cutlist folders, because according to API it is under a non visible “solidbodies” folder in the tree root… so you have to look for “solidbodies” and its subfeatures as well. There is also a case the cutlists are in the root only and both in the root and as a subfeature of the cutlists top folder that apperas in place of the ordinary “solid bodies”…
Actually there is also a fourth case: empty cutlists folders hidden in the tree.
Those must be purged (and I posted a macro to do that) otherwise the list of cutlist folders is going to include them and since they have zero bodies inside, they will cause other issues if not managed.
Are you saying that the feature tree looks different visually? Or that when traversing via the API the cut list items are some times found as features and other times as subfeatures?
Here’s a macro to traverse the tree and print out the cut list items with their associated features:
Option Explicit
Dim mDoc As ModelDoc2
Dim featMgr As FeatureManager
Dim treeItem As TreeControlItem
Set mDoc = swApp.ActiveDoc
Set featMgr = mDoc.FeatureManager
Set treeItem = featMgr.GetFeatureTreeRootItem2(swFeatMgrPane_e.swFeatMgrPaneTop)
traverseItem treeItem
Private Sub traverseItem(item As TreeControlItem)
Dim child As TreeControlItem
Dim nextFeat As Feature
Set child = item.GetFirstChild()
While Not child Is Nothing
traverseItem child
Set child = child.GetNext
Wend
If item.ObjectType = swFeatureManagerItem_Feature Then
Set nextFeat = item.Object
If nextFeat.GetTypeName2 = "CutListFolder" Then
Dim cutListBodyFolder As BodyFolder
Set cutListBodyFolder = nextFeat.GetSpecificFeature2
Debug.Print nextFeat.Name
processCutListFolder cutListBodyFolder
Debug.Print 'Blank line
Private Sub processCutListFolder(folder As BodyFolder)
Dim vBodies As Variant
Dim bodyCount As Integer
bodyCount = folder.GetBodyCount
vBodies = folder.GetBodies
If IsEmpty(vBodies) Then
Exit Sub
Dim i As Integer
Dim nextBody As Body2
For i = LBound(vBodies) To UBound(vBodies)
Set nextBody = vBodies(i)
processBody nextBody
Next i
Private Sub processBody(bod As Body2)
Dim featCount As Integer
featCount = bod.GetFeatureCount
Dim vFeats As Variant
vFeats = bod.GetFeatures
Dim i As Integer
For i = LBound(vFeats) To UBound(vFeats)
Set nextFeat = vFeats(i)
Debug.Print Chr(9) & nextFeat.Name
traverseFeature nextFeat
Next i
Private Sub traverseFeature(feat As Feature)
Dim subFeat As Feature
Set subFeat = feat.GetFirstSubFeature
While Not subFeat Is Nothing
Debug.Print Chr(9) & subFeat.Name
traverseFeature subFeat
Set subFeat = subFeat.GetNextSubFeature
Wend
my trees are visually similar, but according to api, their structure is completely different. it couldbe related to the custom properties since sw changed them like a couple of times since 2012 and our data was made with very old templates.
