How do I “rebend” a bend in a flat pattern in SE?
For example this part I would like to show the bend location of bend 2 after bend 3 is bent.
They can calculate this at the brake but it’s more accurate if I give them the measurement.
In SW I would simply create another Flat Pattern configuration and suppress the one “Flatten” feature.
What is the best way to do this in SE?
There is an Unbend tool to unbend specific bends.
I’m not sure you can rebend a flattened model, but you can unbend a bent model, and then rebend it later. This is all in ordered, I don’t think you can do it in sync.
I think he needs to get a drawing view of bend 3 formed but bend 2 flat so he can show distance from the face of the flange created by bend 3 to the bend line of 2. I couldn’t remember how to show the model with a bend unbent in one drawing view but not others.
I agree, I don’t think you want to put a bend back in the flattened model in SE because I’m pretty sure SE uses that to make the dxf, not at all how SW does it.
That said, I don’t understand why they would want to form 3 before 2, but maybe there’s other things involved, I don’t know. I assume they do not have a CNC break that can read the dxf. We (design eng) never get involved in bend sequencing as metals like to do that, as long as the finished part meets the requirements. I get the feeling that the press operator is requesting that dimension on the print which IMO is a slippery slope. But, I don’t know the full context.
Audio gets bad at the end, but this shows the process. You can flatten any bend you want, but it has to be connected to the flat face. So you could flatten 2 adjacent bends in one flatten feature, but not bends that don’t connect to the same flat face. To flatten bends that don’t connect to the same flat face, you’d have to use multiple Flatten features. sebebd.wmv (8.48 MB)
The main part hits the lower part of the break before the end face reaches the stops, if that makes sense.
We are using a Cincinati CNC break but it doesn’t have the capabilities to import a DXF, unfortunately. I am about to tell the operator to simply figure it out. That’s why we have press brake operators, right?
Thanks for the info matt. I knew about this but the difficulty I ran into was, I would have to save out a “family part” in order to have a unbent and bent version. I don’t really want another file just so I can show this on the print. Is there an easier way to do this without saving out a “family part”?
[quote=“Jaylin Hochstetler” post_id=11361 time=1628703996 user_id=126]
That is exactly what I need.
I should have shown the completed part, then it would have made more sense.
If you form bend 2 before 3, which would look like this:
2021-08-11 13_37_12-Solid Edge 2021 - Ordered Sheet Metal - [8-1013-70.psm].jpg
Thanks for the info @matt. I knew about this but the difficulty I ran into was, I would have to save out a “family part” in order to have a unbent and bent version. I don’t really want another file just so I can show this on the print. Is there an easier way to do this without saving out a “family part”?
Edit: Fixed the pics.
[/quote]
Hi [mention]Jaylin Hochstetler[/mention],
You don’t need to use family of parts to represent bent and unbent version. Here is a short video about steps:
Are you looking for something like shown here so you can have a full flat but as the part gets bent get a representation with the remaining bends and be able to dimension to the bend line from a formed face. This way the press brake operator does not have to add bend allowance to the numbers on a full flat pattern:
I don’t know if there is an automated way to do this in edge. There are some press brake CAM packages that do this.
