How to get the BOM table for a drawing view or for a BOM balloon?
I’m trying to figure out how many rows are in a BOM table that is “attached” to a drawing view that contains BOM balloons. I have been unable to find a method of getting that table, given either the drawing view or given one of the BOM Balloon notes or annotations
Is there a method that I have overlooked?
Thank You
Use view.GetKeepLinkedToBOMName method to get the table name.
For some reason, the link is not working, so you can search in the API help files.
See:
I thought the issue was fixed, but I checked the post again and it is still an issue. Thanks for the updates.
I didn’t understand if the BOM balloons play an important role or if they are simply there in this particular case? Or maybe there is a situation where there is simply a BOM table “attached” to a particular view and we want to know how many lines table has.
Thank you, Deepak. That’s it! Can’t believe I couldn’t find that.
Glad to know it was helpful. And unfortunately this does not work for Cut list tables, and I do not think there is any API call for cut list.
Something like this?
We get the number of rows (visible or all together with hidden for the specification table)
Public Sub ListBomRows_AllSheets()
    Dim vSheets As Variant, vOneSheet As Variant
    Dim i As Long, j As Long
    Dim swView As SldWorks.View
    Dim swSheet As SldWorks.Sheet
    Dim vSheetName As Variant
    Dim bomName As String
    Dim bomAnn As SldWorks.BomTableAnnotation
    Dim ta As SldWorks.TableAnnotation
    Dim Total_RowCount As Integer
    Dim NoHidden_RowCount As Integer
    Set swModel = swApp.ActiveDoc
    If swModel Is Nothing Or swModel.GetType <> swDocDRAWING Then Exit Sub
    Set swDraw = swModel
    vSheets = swDraw.GetViews() ' outer array = sheets
    vSheetName = swDraw.GetSheetNames
    Total_RowCount = -1
    NoHidden_RowCount = -1
    For i = 0 To UBound(vSheetName)
        Set swSheet = swDraw.Sheet(vSheetName(i))
        vOneSheet = vSheets(i)          ' inner array: [0]=Sheet, [1..]=View
        If IsEmpty(vOneSheet) Then GoTo NextSheet
        ' Iterate through VIEWS of this sheet
        For j = 1 To UBound(vOneSheet)
            Set swView = vOneSheet(j)
            If Not swView Is Nothing Then
                'Set swSheet = swView.GetSheet          ' get the sheet from the view
                bomName = swView.GetKeepLinkedToBOMName
                If Len(bomName) > 0 Then
                    Set ta = FindBomTableAnnByFeatureNameOnSheet(swDraw, swSheet, bomName)
                    If Not ta Is Nothing Then
                        Total_RowCount = ta.TotalRowCount
                        NoHidden_RowCount = ta.RowCount
                        If Total_RowCount >= 0 And NoHidden_RowCount >= 0 And Total_RowCount = NoHidden_RowCount Then
                            Debug.Print bomName & " : "; NoHidden_RowCount
        Next j
NextSheet:
    Next i
' Find TableAnnotation of BOM by BOM feature name (bomName) on a specific sheet
Private Function FindBomTableAnnByFeatureNameOnSheet( _
        swDraw As SldWorks.DrawingDoc, _
        swSheet As SldWorks.Sheet, _
        bomName As String) As SldWorks.TableAnnotation
    Dim curSheet As String, targetSheet As String
    Dim feat As SldWorks.Feature
    Dim bom As SldWorks.BomFeature
    Dim vTA As Variant
    Dim i As Long
    Dim sheetta As SldWorks.Sheet
    Dim featName As String
    Dim bomFeat As SldWorks.Feature
    Set swModel = swDraw
    curSheet = swDraw.GetCurrentSheet.GetName
    targetSheet = swSheet.GetName
    ' In case of split-BOM, activate the required sheet (not strictly necessary, but useful)
    If StrComp(curSheet, targetSheet, vbTextCompare) <> 0 Then
        swDraw.ActivateSheet targetSheet
    Set feat = swModel.FirstFeature
    Do While Not feat Is Nothing
        If StrComp(feat.GetTypeName2, "BomFeat", vbTextCompare) = 0 Then
            ' Feature name (this is what View.GetKeepLinkedToBOMName returns)
            featName = feat.Name
            Set bom = feat.GetSpecificFeature2
            If Not bom Is Nothing Then
                Set bomFeat = bom.GetFeature
                If Not bomFeat Is Nothing Then featName = bomFeat.Name
                If StrComp(featName, bomName, vbTextCompare) = 0 Then
                    vTA = bom.GetTableAnnotations  ' array of TableAnnotation (takes split-BOM into account)
                    If Not IsEmpty(vTA) Then
                           For i = LBound(vTA) To UBound(vTA)
                            Set ta = vTA(i)
                                Set FindBomTableAnnByFeatureNameOnSheet = ta
                        Next i
        Set feat = feat.GetNextFeature
    Loop
        swDraw.ActivateSheet curSheet
End Function
Immediate window resalt:
Bill of Materials1 :  19
see: GetHeaderCount and GetHeaderStyle
