How to enable "Thread class" in Hole Wizard Property Manager
I am trying to edit the definition of an existing hole wizard hole. I can figure out how to change all the settings in the following image, except I can’t figure out how to enable/disable the check box before “Thread class”
For example, I use the statement
swWizHole.CosmeticThreadType = swCosmeticThreadWithoutCallout
to disable the “With thread callout” check box
I would expect a statement like
swWizHole.ThreadClass = true
would check the “Thread class” box, but it doesn’t (I just made up that property)
Any ideas how I can enable the “Thread class” check box?
ThreadClass Property (IWizardHoleFeatureData2) requires a string value:
One of the following thread classes:
1B
2B
3B
This property is relevant only for the ANSI inch standard.
see https://help.solidworks.com/2024/english/api/sldworksapi/solidworks.interop.sldworks~solidworks.interop.sldworks.iwizardholefeaturedata2~threadclass.html
I totally understand your frustration. To enable the “Thread class” checkbox in the Hole Wizard Property Manager, you might want to try using the swWizHole.ThreadClass property
Thanks, retonny77. Here’s a snip of my code
swWizHole.ThreadClass = "2B" 'Note that this doesn't seem to enable the "Thread class" check box.
Are you getting different results?
I still have not been able to make this work (2023 SP5). Hoping someone else knows something I don’t. Thanks.
