How to create several empty folders in feature tree?
Total newbee in macros.
I’m trying to run a macro to add several empty folders in feature tree.
After folders being created, different features will be manually drag into these folders.
The code at the bottom is what I have so far.
I’m receiving this error:
run time error 438
Object doesn’t support this property.
on this line:
Set swFeat = swFeatMgr.InsertFeatureTreeFolder3(1, 0)
Thanks for any kind of help.
    Dim swFeatMgr As SldWorks.FeatureManager
    Dim folderNames As Variant
    Dim i As Integer
    Set swModel = swApp.ActiveDoc
    If swModel Is Nothing Then
        MsgBox "No active model open.", vbCritical
        Exit Sub
    Set swFeatMgr = swModel.FeatureManager
    folderNames = Array("Body", "Ws", "Holes", "Studs", "Taps", "Brs", "Trims", "Locs", "Ens")
    For i = LBound(folderNames) To UBound(folderNames)
        If Not swFeat Is Nothing Then
            swFeat.Name = folderNames(i)
        Else
            MsgBox "Folder creation failed on: " & folderNames(i)
            Exit Sub
    Next i
Forgot to say, I’m still on SW2022 SP5.
Thanks again.
2 things
This line “Set swFeat = swFeatMgr.InsertFeatureTreeFolder3(1, 0)” should be “Set swFeat = swFeatMgr.InsertFeatureTreeFolder2(1)”
1 Indicates an empty folder before a selected item.
Now in order to add a folder via API, you need to have something selected. So you can either add a sketch or feature first (can be manually or via API), select that and add the folder. And finally delete that sketch or feature.
Its AI fantasy.
Option Explicit
        MsgBox "There is no active SOLIDWORKS document.", vbExclamation
        Exit Sub
    Dim docType As Long
    docType = swModel.GetType
    If docType <> swDocPART And docType <> swDocASSEMBLY Then
        MsgBox "The macro works only with a Part or Assembly.", vbExclamation
        Exit Sub
    Dim i As Long
        Call AddEmptyFolderIfMissing(CStr(folderNames(i)))
    Next i
    swModel.ClearSelection2 True
    swModel.EditRebuild3
    MsgBox "Done. Folders added.", vbInformation
Private Sub AddEmptyFolderIfMissing(ByVal folderName As String)
    If FolderExists(folderName) = True Then Exit Sub
    Dim swFirstFeat As SldWorks.Feature
    Set swFirstFeat = GetFirstUsableTopFeature()
    If swFirstFeat Is Nothing Then
        MsgBox "Unable to determine insertion location for folder:" & folderName, vbExclamation
        Exit Sub
    Dim ok As Boolean
    ok = swFirstFeat.Select2(False, -1)
    If ok = False Then
        MsgBox "Unable to select feature to insert folder:" & folderName, vbExclamation
        Exit Sub
    Dim swNewFolder As SldWorks.Feature
    Set swNewFolder = swFeatMgr.InsertFeatureTreeFolder2(1)
    If swNewFolder Is Nothing Then
        MsgBox "Failed to create folder: " & folderName, vbExclamation
        Exit Sub
    On Error Resume Next
    swNewFolder.Name = folderName
    On Error GoTo 0
Private Function GetFirstUsableTopFeature() As SldWorks.Feature
    Dim i As Long
    Dim featName As String
    Dim featType As String
    Set GetFirstUsableTopFeature = Nothing
    For i = 0 To swModel.GetFeatureCount - 1
        Set swFeat = swModel.FeatureByPositionReverse(i)
            featName = ""
            featType = ""
            featName = swFeat.Name
            featType = swFeat.GetTypeName2
            On Error GoTo 0
              ' Find Origin and paste it after it.
                If InStr(featType, "Origin") <> 0 Then
                    Set GetFirstUsableTopFeature = swModel.FeatureByPositionReverse(i - 1)
                    Exit Function
    Next i
End Function
Private Function FolderExists(ByVal folderName As String) As Boolean
    FolderExists = False
    Set swFeat = swModel.FirstFeature
        If StrComp(swFeat.Name, folderName, vbTextCompare) = 0 Then
            If LCase$(swFeat.GetTypeName2) = LCase$("FtrFolder") Then
                FolderExists = True
                Exit Function
        On Error GoTo 0
    Loop
End Function
Here is one more similar code
Option Explicit
    Dim swSketchFeat As SldWorks.Feature
    Dim i As Integer
        Exit Sub
    swModel.Extension.SelectByID2 "Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0
    swModel.SketchManager.InsertSketch True
    swModel.SketchManager.CreateCornerRectangle 0, 0, 0, 0.1, 0.1, 0
    Set swSketchFeat = swModel.FeatureByPositionReverse(0)
    swSketchFeat.Select2 False, 1
    For i = UBound(folderNames) To LBound(folderNames) Step -1
        Else
            Exit Sub
    Next i
    swModel.EditDelete
Did the magic.
I wonder why the order of the created folders is reversed.
I have to step into code to see what’s going on.
I have to run, so I didn’t test other suggestions. I’ll test and will come back as soon as I’m back to my desk.
Thanks to all
It basically adds the folder before the selected feature. So when a new folder is created, it is selected by default, and next folder will be added before it. Hence you need to add the folders in reverse.
Interesting. Since I am not a macro running guy my thoughts on how to do this go to setting up a template that will already have empty folders in them.
@mihkov Thanks for trying to help.
Your suggested code adds the necessary folders, but has two problems.
1- It always add the folders at the top of the feature tree (bellow Origin), regardless of which feature is selected.
2- If I’m in an assembly and select a feature inside a component, the folders are added to the assembly and not to the selected component.
My code, and later corrected by @gupta9665 adds the folder above the selected feature, and if in an assembly, they are added to the selected component.
Thanks again for your input.
Yes, that’s what I’m doing now. Our recent template has the folders. But when I need to work on an old file, that doesn’t contain the folders, I have to add them manually. A macro needs a click to add all.
@gupta9665 A note about the version you suggested:
1- If I open a part and run your macro, a sketch is added to the bottom of the feature tree, then I receive an error saying : Folder creation failed on: Ens
The code stops and nothing’s added
2- If I open an assembly that contains several components, a sketch is added to the bottom of the feature tree, all folders are added, then I receive a message that if I want to delete the sketch.
I think it’s a little bit over kill.
Million Thanks for all your efforts and help.
With your help, I have a perfect working macro that exactly does what I was trying to achieve.
Thanks again.
It worked for me in the part without any errors. I did not tested it for the assemblies.
Did you used the same codes I posted above OR did you used portion of it, with your codes?
And will you be willing to share what worked for you?
The working code is what I posted in my first post above, and the correction of one line you suggested.
  1. If a part is opened and a feature is selected : it adds the folders above the selected feature.
  2. If an assembly is opened and a component is selected : it adds the folders above the selected component.
  3. If an assembly is opened and a feature within a component is selected : it adds the folders above the selected feature inside the component.
It works the same for both virtual and externally saved components in an assembly.
    Dim i As Integer
        Exit Sub
        ' Create folder (type argument = 1 = Feature folder)
        Else
            Exit Sub
    Next i
I clicked the copy button above your code and pasted it in a new macro, named it test and saved and then ran it.
Well I was able to use the macro without any error codes. So not sure what went wrong.
Anyways, glad to know that you have the working version. And thanks for sharing it.
:police_car_light: Critical code issues:
  • No check for folder existence - inserting folders that already exist will result in an error.
  • No check for selection - if nothing is selected, the macro will silently do nothing.
:construction: Non-critical code issues:
  • No document type check - you can, for example, run it in the active drawing.
  • No check that the returned object is actually a folder, for example, via GetTypeName2.
  • No model rebuild/tree update - even with EditRebuild3, the folders may not be visible, and you might run the macro again and get the error.
This macro is only for those who know all the initial conditions. :face_with_monocle:
Will give it another try. If I still face any errors, will upload a file that shows error. But it takes a day or two. So busy right now.
Thanks again.
I was trying to keep things as simple as possible for the forum, so I didn’t feel the need to clutter the page with obvious checks.
Assemblies and drawings are configured to display specific customized toolbars. Otherwise, the screen would be cluttered with unnecessary buttons. Now that you mention it, I’ll add this check just to be safe.
During all my tests, I didn’t face any situation where the folders were added but not visible. But if you think it may happen and there’s a possibility, I think I will add this too. Thanks.
To be honest, I don’t know what does this mean and how it can be helpful. When I’m adding a folder via a macro, can the return object be different? Any further explanation, how it may occure or how I can check this is much appreciated.
Of course, this only applies to those who are familiar with the conditions. We are a small company with just a few people using SolidWorks. The goal of this thread was to find a way to simplify OUR daily tasks, not to offer a macro for general use.
I really appreciate your concerns and inputs. And all the time you spent to help.
Million thanks.
Here’s a simple part that triggers the error I mentioned above. I’ve also included a macro based on your suggestion so you can check whether I’ve made a mistake.
test.swp (62 KB)
Part6.SLDPRT (58.4 KB)
Thanks again.
In my code I was using FeatureByPositionReverse(0) to select the last created feature. So when you used it for a sheet metal part, it was selecting the flat pattern feature instead of the created sketch. Hence you were getting the error.
So if you change these lines
to
Set swSketchFeat = swModel.SelectionManager.GetSelectedObject6(1, -1)
it should work.
I also realized that this line swSketchFeat.Select2 False, 1 was not required.
