In need of being able to generate alpha-numerically numbered points from sketch points and also create a corresponding XY-chart/table. SolidWorks can generate an XY-Hole table with ease, but find this does not seem to be an available function for simple sketch points alone.
Does anyone have success in creating such labels and corresponding tables?
Do you need the sketch point to be parametric linked to the table?
If you dont need them to be paramtric linked a macro might do the trick
https://www.codestack.net/solidworks-api/document/sketch/export-point-coordinates/
